For Sale 1983 XJ 750 parts available
Discussion in 'For Sale, Trade/Swap, Wanted' started by xtmag, Sep 12, 2018.
  1. xtmag
    xtmag Member
    Rochester, MA
    Hello all,
    I recently bought a parts bike, 1983 XJ 750 to swap the forks to my xj650 so I can have dual discs up front.
    Everything else is for sale on the bike. It is a running/driving bike so let me know what you need, all prices will be reasonable.
  2. kerriskandiesinc
    NY
  3. xtmag
    xtmag Member
    Rochester, MA
    I'll post when I get home tonight
    Terry Marshall likes this.
  4. Door dude
    Door dude Active Member Premium Member
    Mountain Home Arkansas
    Is this a 750 j or m ? Maxim / seca ?
  5. xtmag
    xtmag Member
    Rochester, MA
    It is a Maxim. Not sure about the J or M part. What is the difference?
  6. hogfiddles
    J-1982
    M - 750 Midnight Maxim
  7. Bluegray57
    Bluegray57 Active Member
    US
    Would enjoy seeing the trials and tribulations of the dual brake conversion.
  8. hogfiddles
    It's a direct swap from 650 maxim front to 750 maxim front. Swap the whole triple tree and everything for the suspension and brakes
  9. xtmag
    xtmag Member
    Rochester, MA
    Thanks for the tips! Yeah I’ll take some pics and post a write up on it. Luckily the xj650 wheels are predrilled for the second rotor!
    Here are some pics.
    Let me know what you need. 2E8BB520-401D-44DE-9274-CFB7686C955D.jpeg 8983D913-3888-4A2A-8CB6-8488D7EEF82C.jpeg 4AD887FD-83BE-4AFF-B717-58D85374CE5F.jpeg 513CC211-E4D6-4EC4-B036-8D4AA133E9DC.jpeg 68299515-43D3-46A3-8EB3-2E09B9C7095B.jpeg 512F84EE-2067-49F8-A38E-F3AE7CC13800.jpeg
  10. hogfiddles
    Correct, cuz they're the same thing. All you do is pop the plastics cover off. OR leave the whole assembly intact from the 750 and slide it out of the triple clamp, swap the triple over, and stuff it back in.
  11. 750MaximSeattle
    750MaximSeattle Active Member
    Seattle, WA
    I'd like to buy the LOCKSET, if the key that's in the ignition also fits all the other locks including the seat/helmet lock, fuel cap, and wheel lock chain. Thanks!
  12. 750MaximSeattle
    Seattle, WA
    Yes, that would work if it were an xj750K model but since your reply there are photos posted and it's sure looks like a J, which I believe was only sold as a 1982 model in the USA. And working from a J creates a problem, the triple tree is different and will not mount his 650 (round) headlight stay, nor the (round) gauges, nor his 650 handlebars. So, given all that, would it be best to mate the 750 lowers to the existing 650 tubes? The xj750K basically has an xj650 front end except for the dual disc brakes and brake lines and lower forks (with mounts for dual disc system). Buckhorn handlebars are another difference, which I believe requires a longer brake line from handlebar to "T" joint. And he will need a dual bango bolt at the "T" joint...and for that matter replace the two existing xj750J lines with (longer) xj750K lines to stretch from the "T" joint on the xj650. Basically, mimic the xj750K brake system design. BTW, I have some experience with this from recently restoring my 1983 xj750K (Canada model), which was missing among other things the entire front brake system except for the rotors (see photo below). Also, those handle bars shown in my top 2 photos are obviously not stock so I replaced them with xj650 Maxim bars...hope to find xj750K bars or xj550 Maxim bars, which are similar to stock xj750K.
    XTMAG, I happen to have a spare (new) double bango bolt for the "T" joint, if you need one.
  13. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    no mufflers then?
  14. xtmag
    xtmag Member
    Rochester, MA
    PM Sent!!
    Thank you for the offer! once I dig in, I will be happy to have it!
    No mufflers came with the bike.
  15. tknaul
    tknaul New Member
    New Hartford NY
    I am looking to purchase a TCI ignition box, Type TID14-06 5G2-10, for a 750 Maxim.
  16. hogfiddles
    Hey, I'm just down the road from you......
    Just below Waterville. Send me a private conversation.
    Dave Fox - Host
    Central NY Carb Clinic
  17. xtmag
    xtmag Member
    Rochester, MA
    PM sent, let me know if don't get what you need from Dave.
  18. xtmag
    xtmag Member
    Rochester, MA
  19. xtmag
    xtmag Member
    Rochester, MA
    Ok, so after some digging, it is not a 1983, it's a 1982. I'll update the heading fo this post. Parts still available!
    750MaximSeattle likes this.
  20. xtmag
    xtmag Member
    Rochester, MA
    Ok, wait, I can't update the posting title. But anyway, let me know what you need!
  21. hogfiddles
    We swapped things around--- his TCI was not cooperating with my bike, so he went home with a working one. His bike still did not cooperate, and it appears that one of the pickups may be the issue, so I'm going to try and pull pickups this weekend.
    I'm hoping he posts his readings here so we can get the electrical gurus working on this too....
  22. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    Hi, this is my very first post on this forum. I just bought an 82 750 Maxim that is missing the carburetors and need a set of carburetors complete. If you have them for sale let me know, price and condition. One more thing, the side covers, ditto, price and condition via email is cool. Thanks for a reply.
    Cheers, 50gary
  23. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    are carbs & instrument cluster available
  24. 50gary
    Saginaw, Mi. USA
    I have an instrument cluster.
    Cheers, 50gary
  25. hogfiddles
    Swapped out the pickups and it solved the problem--- his TCI was fine, too... he rode down earlier today to drop the test TCI off, and I balanced the carbs while he was here, too.... along with replacing a pair of broken reflectors, and a missing Ignition switch/handlebar cover :)
  26. xtmag
    xtmag Member
    Rochester, MA
    Instrument cluster available!
    I’ll send you a PM.
  27. xtmag
    xtmag Member
    Rochester, MA
    Hi All,
    One of the members approached me about the ignition coils. I tested them and one was good and within spec. The other one has no resistance on the wires but it does on the plug boots and harness. Any ideas? $20 plus shipping if anyone wants them.
  28. Nate98
    Nate98 New Member
    Galion, OH
    Hey, I'm interested in the gas tank if you still have it
  29. xtmag
    xtmag Member
    Rochester, MA
    Already sold!
  30. bstig60
    bstig60 Member
    Sharpes, Florida
    I might be interested in the instrument cluster if it will fit my 82 Seca 750RJ
  31. xtmag
    xtmag Member
    Rochester, MA
  32. bstig60
    bstig60 Member
    Sharpes, Florida
    OK, I will be looking for the pics....
  33. XJ550H
    83 750 maxim has the standard round cluster no the atari style
  34. xtmag
    xtmag Member
    Rochester, MA
    Mine is an 1982 xj750. Realized to late to change the thread title.
    Here are some pics:
    AA6214FA-B551-4629-A770-02C31ECBEB7C.jpeg DD57FFF0-02AB-49DE-8938-C268EE8C9304.jpeg D3FD8D12-49C2-4B94-83C0-6465AB18844A.jpeg 12C5F3D2-86A1-4D68-8632-2B5EF37F5449.jpeg 3F0711A3-69AB-4B24-B503-A6D087C2BAF6.jpeg D8BD0180-A854-4D96-BD8B-6F8A1E4D73FC.jpeg 964006E6-DCC9-4F97-B8C4-90CA3872BFE8.jpeg
  35. bstig60
    bstig60 Member
    Sharpes, Florida
  36. xtmag
    xtmag Member
    Rochester, MA
    Email sent!
