Fattest tires that will fit?
Discussion in 'XJ Technical Chat' started by DimaV, Oct 15, 2018.
Tags:
  1. DimaV
    DimaV Member
    Kyiv, Ukraine
    Sup!
    Want to change tires and I wonder what can be the widest tire (front and rear) on Yamaha xj650 1982 Seca?
    Undoubtedly, wider tire looks cooler on custom project but, of course, there are limits.
    Appreciate ur help.
  2. Taylo105
    Taylo105 Active Member
    San Diego CA
    For the rear, the research i've done has pointed to a 130 for the width to avoid any rubbing issues on the driveshaft. I'd love to know if anyone has any other info as I'm looking to modify my rear.
    I'm actually contemplating putting a maxim rear rim on my seca as my front end swap switched to a 17 front rim from the standard 19, so I need to better "balance" the bike. This would allow the rims to better match the size. I know @Jish did this swap for this project seca too.
  3. k-moe
    130 rear. Stock front.
    Wider isn't better if the bike wasn't built to lean far enough to use the extra width.
  4. DimaV
    DimaV Member
    Kyiv, Ukraine
    by front stock you mean 100/90/18 ?
  5. k-moe
    That's the metric equivalent for the stock size, yes. Trying to stuff something wider on the rim tends to not work so well.
  6. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    100/90-19 actually
    Crankwalk and k-moe like this.
  7. k-moe
    Yep. Mr. Teacherman is a poor reader this week.
  8. a100man
    a100man Well-Known Member
    Bedford, UK
    DimaV, I have no input to make regarding the tyre. However as my wife has recently walked out I find myself occasionally in need of female company - are there any more like the one in your Avatar about? I will gladly bring along the fattest rear tyre money can buy if the arrangement is suitable.
  9. joejr2
    Santa Fe,NM
    The balance we seek is to spend as much time in the garage working on bikes as we can without having the little lady walk out.
  10. a100man
    Bedford, UK
    Bugger! Who knew?
  11. Bluegray57
    Bluegray57 Active Member
    US
    I thought the balance was to work on the bike less and ride it more.
    Chitwood likes this.
  12. Rowan Mickan
    Rowan Mickan New Member
    I run a 110/90/19 up front
    And a 130/90/18 on the rear.
    Absolutely no rubbing.
    Good luck trying to find tires that match in those sizes though. I had to search for ages until I found anaussie brand that fits
    RideAlong420 likes this.
  13. XJ550H
    ride the bike?
