Wanted XJ900 R mikuni bs35 carbs
Discussion in 'For Sale, Trade/Swap, Wanted' started by Jaedee2, Nov 13, 2018.
  1. Jaedee2
    Jaedee2 New Member
    Hi all, on the hunt for a full rack of mikuni bs35 for my 1983 XJ900 R.
    Unfortunately all diaphragms on mine have teared and the support holding #3 carbs' float has cracked. Will pay for postage to Australia.
    Cheers,
    Jamie
  2. chacal
    Hi Jamie, we do have the complete vac piston diaphrams, and complete vac piston units (with the diaphragm installed) available, as well as a bare carb body (with a good post). Just send an e-mail to us for all of the information regarding prices, availability, ordering: info@xj4ever.com
  3. Jaedee2
    Jaedee2 New Member
    Cheers Len, at this stage I'm trying I'll try my luck to source a complete rack. I'll let you know if nothing comes up.
  4. chacal
    Okay Jamie, just let me know if we can be of any help!
  5. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    I just fixed my broken float support left side #1 carburetor. Drilled it with a very small drill (on a milling machine, both the base and post) cut the drill shank off and used it for the pin. Then used JB Weld to fasten it together, works great. JB Weld is a cold weld metallic epoxy commonly used for odd repairs.
    Then just buy the diaphragms, done.
  6. XJ550H
    JB weld will fail after a while there is a thread about a guy who can weld the post for you
  7. motorcyclefanatic
    motorcyclefanatic New Member
    Flatistan
    Just sent you a pm.
