Petcock Swap
Discussion in 'XJ Technical Chat' started by SwIrv, Nov 15, 2018.
  1. SwIrv
    SwIrv New Member
    Fairfield, CT
    I just finished rebuilding my petcock when I turned to install in into my gas tank I knocked over my gas tank.:mad: Long story short I now have a massive dent:(. I recently saw someone swap an xj650 gas tank with an xj700, would my xj650 petcock fit the xj700 gas tank?
  2. Toomanybikes
    Tsawwassen bc
    Welcome Swirv
    The xj650 maxim tank is a direct swap with the 82-83 XJ750 maxim,
    but not the Xj700n 85-86.
  3. XJ550H
    xj 750 tank will fit the bike
    you could have the dent removed tools run 30 to 125$ to do it
  4. Fuller56
    Fuller56 Well-Known Member
    Check your local yellow pages for a "paintless dent repair" outfit. They are amazing at manipulating tools and working dents out from the inside. A guy here in Cary, NC fixed hail damage to my black truck in 1 day leaving it so that you would never know it had been damaged. Likely the price for a m/c tank would be very reasonable, maybe less than shipping in another tank.
    XJ550H likes this.
  5. chacal
    No, the XJ700 petcock is much wider and the mounting bolt holes won't line up.
  6. SwIrv
    SwIrv New Member
    Fairfield, CT
    Thanks for the input, I'm learning a lot on this forum.
