cold blooded at first - then pops warmed up
Discussion in 'XJ Technical Chat' started by turpentyne, Jan 21, 2019.
  1. turpentyne
    turpentyne Active Member
    Desert SW
    I need some outside opinions on next steps with this '82 750 Maxim. Maybe there's a few suggestions before I pull the rack back out.
    The carbs were completely rebuilt -- church clean. Racks broken down, replaced jets, everything cleaned - including the itty bitty holes people tend to miss. pilot fuel jets are #41 , main fuel jets are #120. Stock airbox, new spark plugs, shims adjusted. Carb tuned, color tuned. rain danced. The whole shebang...
    But... even with that effort, I go out to start it up each weekend and fiddle with tuning, but no luck. I have to spray starter fluid into the airbox and try about 10 - 20 times to get it to start. With the choke full on. And it's about 60 degrees out.
    Then, once it starts, it does just fine. warms up for a few minutes. Once it's good and warmed, I can hear a few pops out the right exhaust when I blip the throttle. While I was color tuning, I could see it was likely the #3 cylinder. The mixture screws are all just a hair past 2 1/2 turns. I tried turning that back and forth on carb 3 to get rid of the pop, but it didn't matter.
    My suspicion is that I need to pull the carbs off and go through the little tiny enrichment hole again. But I did the carb-spray test, and they seemed good. I also may want to replace the carb 3 mixture screw. The others are new. that one seemed good enough to clean and leave alone, but maybe that was a bad decision.
  2. k-moe
    Check for exhaust leaks.
    Pics of the plugs would be helpful. Uee a neutral background.
    Did you prime the float bowls prior to attempting to start the machine?
  3. turpentyne
    Desert SW
    I'm not using the gas tank, just a little fuel-safe plastic container with a manual on off switch. Since it's not working off vacuum, maybe that's part of the problem?
    I did see a little white smoke coming from around where the exhaust comes out of cylinders 3 & 4 - I hadn't thought about it yet, thinking maybe it was just a little condensation.
    I have been putting off messing with exhaust because I'm a little gun-shy about breaking bolts.
  4. XJ550H
    did you plug the vacuum line?
  5. turpentyne
    Desert SW
    Yep, it's plugged. and they're all new rubber caps - the old ones were fossilized. Also, checked for vacuum leaks and nothing seems wrong, there either.
    Next I think I'll grab a squirt bottle and check for exhaust leaks
  6. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Sounds to me like you still have a problem with the carbs, most likely the pilot circuit. Also, check for a leak around the intakes. I had a gasket with about 1/2 of it missing.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    At first I read the title as "my dad didn't want me getting a motorcycle at first and then he warmed up to the idea"
    LOL
    Jetfixer, turpentyne and XJ550H like this.
  8. XJ550H
    did you clean out the wells in the carb bowl that the tube goes into? that's what feeds the enrichment circuit (choke)
    Jetfixer likes this.
  9. turpentyne
    Desert SW
    Yep cleaned the wells, cleaned the tiny enrichment circuit holes. I can't think of a part I didn't clean.
    I am a little concerned that after wet-setting it and putting it on the bike, I was forced to wait two or three weeks before getting back to the bike and starting it up. I wouldn't think 3 weeks would be enough for any leftover fuel to gum anything up... but, heck... anything's possible.
    If I have enough light when I get home from work some night his week, I'm gonna check for exhaust leaks and check that off the list. if that's good... well, I'm suspecting I need to pull the carbs and clean the bowls again just in case. Simple enough, aside from the annoyance of it all.
  10. XJ550H
    did you clean the enrichment tube? no tiny holes in the enrichment circuit except in the tube are you talking about the pilot jet and mixture screw holes on the top of the throat by the butterfly disc?
    did you replace the o rings on the mixture screws spring then flat washer then o ring onto the screw.
    then the bench sync?
  11. XJ550H
  12. turpentyne
    Desert SW
    Every piece of rubber has been replaced. All jets are new. Cleaned every orifice possible in the body, in the bowl. This was a complete soup-to-nuts rebuild.
    Not to say it doesn’t need to reinspected, but this is a case of hospital clean, and still a little fussy
  13. Rooster53
    North, FL
    Even with an external tank make sure the carbs are actually filling. A week is long enough for the gas to evaporate from the bowls. Use a clear tube to verify the bowls are filling all the way. Bowls not full makes for a hard start cold.
    What did you see with the color tune on #3 that made you suspicious? All new rubber... does that include the intake manifolds with new gaskets?
  14. turpentyne
    Desert SW
    Got home early enough, and just used the spray bottle of soapy water method, and didn't see any obvious exhaust leaks, at the heads.
    At four days between, it wasn't quite as hard to get her going, but still required the starting fluid.
    I've got clear hose on there, and and I turn it on then wait a couple minutes for the fuel to fill. Maybe I'm still being too impatient. ... oh! wait... do you mean attaching a hose to the drain plug, like when wet-setting? Why the heck didn't I think of that! Yeesh!
    At the same time I hear pops, the color flashes white for a second, then goes back to blue. None of the other plugs did it.
    Everything seems close to a basically decent tune, except for the popping when it warms up and I give a little throttle. I presume a touch lean.
    Maybe, this weekend I need to just pop the carbs off and clean things for kicks. It'll give me a chance to replace the mixture screw on #3 with a brand new one, too. (unless someone's successfully replaced that and the washer/o-ring while on the bike?)
  15. turpentyne
    Desert SW
    Missed this question... No, They're still the manifolds that were on there. I just meant all the rubber parts within carb. But, they've been coated with high-temp RTV and wrapped with high-temp silicone tape. I just double checked for vacuum leaks, and nothing... or at least nothing findable with the carb cleaner spray method.
  16. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I have had a pick up coil fail when it got hot. When it failed it would back fire. Yours might be failing intermently. Just a thought.
  17. XJ550H
    have you tried a new spark plug or swapping the plug with another to see if the problem follows the plug?
    you can also plug wire 2 and 3 see if the problem follows the wire and cap.
    if it does
    then just swap the caps see if the problem follows the swapped part.
    this would not address the lean then blue colors #3 cylinder do yo have the vacuum hose connected to cylinder 3?
    do you have the stock air filter?
  18. turpentyne
    Desert SW
    Stock airbox and filter, brand new spark plugs and brand new plug caps. But, I'll try switching them around - they could be bad for all I know.
    Right now all four vacuum ports are blocked, since I'm just running a simple fuel line from a container.
    Cool. a couple things to try this weekend. I haven't replaced pickup coils, so that's worth looking at, too.
  19. Rooster53
    North, FL
    Yes, that is what I was thinking. It's the best way to make sure fuel is really flowing and the bowls have filled.
    Another thought on cold start after sitting is low compression. Have you ever checked the compression?
    +1 on the electrical suggestions above just to rule those out as a cause of the popping. After that, maybe try backing the mixture screws for 3 and 4 carb out to around 4 turns to see if it cures the popping.
    And as k-moe suggested looking at the plugs might provide a clue even though it sounds like you haven't really made it out for a ride as of yet.
  20. turpentyne
    Desert SW
    ok.. looks like I've got a beginner question...
    Before starting up the bike and trying a couple things, I'm checking the pickup coils, and I decided to check out the ignition coils and get that possibility out of the way.
    Pickup coils seem (mostly) good. I've got 6.58 ohms at the orange wire, and 6.69 at the grey. Even though I'm getting spark, I figured I might as well check ignition coils since I was at it.
    For primary, both coils gave me 2.8 ohms. Then, testing for secondary... I got nada, zip, zilch, OL.
    I tested a few ways - I tested from the pigtails to the plug cap, I tested pigtail to the wire - with plug removed. Then, I put the pigtail back and tested between wire #3 copper and wire #4 - both through the cap, and without the cap. They've been trimmed back to clean metal, and the caps are brand new.
    So my conclusion is... I'm doing something wrong. :)
    EDIT - on a side note, I just attached a clear tube to #1 carb, and that most definitely is the starting issue. It's not pulling gas into the bowl. What little bit was sitting in the bowl from last weekend came out, and that's it. Choke is on, and I gave it a couple tries starting, to see what happened. Opened the cap of my fuel container, in case vacuum wasn't letting it flow. Thoughts?
  21. XJ550H
    you test the secondary from sparkplug wire to spark plug wire. wire 1 and 4 then wire 2 and 3 . you also test the caps Meter set to high enough range to read?
    XJ750 air-cooled models:
    Pick-up coils:
    650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    1981-83 models: 5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    1984 RL models: 10K +/- 20% = 8,000 to 12,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
  22. turpentyne
    Desert SW
    Went out and double-checked everything, once @XJ550H pointed out I was testing between the wrong wires. I did a quick test (with caps still on) and DMM set to 200k and got a reading of 21.00 between 1 and 4 wires, and 20.5 between 2 and 3. On pickup coils, the readings were 658 and 669. I think was just reading with the decimal in the wrong spot.
    Then I checked all the bowls, and they seemed full and fine. I pushed the ignition and it started up, first try.
    Maybe I've just been too impatient waiting for the bowl to fill. Or maybe it's just because I'd tried enough times earlier.
    Now that I got a little swagger back, I'll pull the caps and check the readings.
  23. turpentyne
    Desert SW
    Ok... here's an odd update... while typing my previous note, the bike was out there warming up. I went back out, and blipped the throttle a couple times. I could hear the popping a little, but after a couple minutes it actually went away.
    Only thing I've done is take the spark plug caps off when checking them. I did snip an extra half centimeter off wire #3.
    Aside from the fact that it still popped a couple times... was my issue just a combination of being impatient waiting for bowls to fill and .. maybe a new cap wasn't quite on there well enough? Oh.... Except that I saw the popping while colortuning, so the cap isn't the issue.
    Dang.. now I'm stumped on whether I have any problem at all. hahaha! Maybe It's the nut that connects the seat to the handlebars?
  24. XJ550H
    sounds like it is time to tune your carbs running sync and color tune.
