Painting engine block?
Discussion in 'XJ Technical Chat' started by regulator, Apr 27, 2006.
  1. regulator
    regulator Member
    Ankeny, IA & Brooklyn Center, MN
    I was considering painting my engine black, using engine paint (1500 temp) but a friend had made a comment to me about the motor possibly not getting cooled enough if I do this??? I can see peeled black paint on the lower half of my block (must have been black at one point) but not the upper half. Will painting the block really hurt the cooling?? I saw a article some where that sounded awesome and would like to try, about painting the block, then running a drimmel with a fine sander wheel over the edge of the fines to have the "silver" edges shine thru giving a great accent to the engine, but now I am hesitant to try after hearing the cooling issue, any helpful comments would be appreciated.
    (82 XJ 750 Maxim by the way)
  2. Jazzmoose
    Jazzmoose Member
    Pineville, LA
    Actually, I'm pretty sure that black paint on an engine block will HELP the cooling. It's not the same as absorption of heat, where white reflects and black absorbs heat. In the radiation of heat from a hot source to the atmosphere, black should accelerate the dispersal of heat. Or something like that...
  3. jasonlion54
    jasonlion54 Member
    Seattle, WA
    True about the color black, but the paint itself might actually insulate the engine block, thus slowing heat transfer. I might be way off, but it's something to consider.
  4. Brian750R
    Brian750R Member
    Boston MA
    I dont think it should create too much of a problem, providing you apply a light coat, however I still wouldnt do it too my bike...
  5. Joel07
    Joel07 Member
    Durham, NC, USA
    The Midnight Maxim's all had black engines from the factory, so it can't be that huge of a difference. I know a lot of air-cooled VW guys that won't paint their blocks, there's probably some truth to it, but for a street driven bike that will probably only see occasional abuse, I wouldn't worry about it.
  6. Robert
    Painting the surface (even with a flat finish) will diminish the cooling capacity of the surface area as Jason mentioned. This loss of surface area can be off-set with the addition of an auxilary oil cooler (not too expensive and worth the investment if you ask me) if you are worried about it. With air/oil cooled engines, any cooling you can pick up is usually a very good idea (Antarctica being an obvious exception). I blasted and painted my engine this past year and have added the cooler. I haven't got the engine back in the bike but I will be installing an oil temperature gauge to be able to follow what is going on inside and will report back to you all. I would do it but add the cooler, it looks nice.
  7. regulator
    regulator Member
    thanks all, once again good advise, the paint coating the engine was my concern. I did notice a couple engine blocks that where painted last night at a get together, most where liquid cooled, but did see a few that were air cooled, no one said they had issues but still would like to hear more thoughts, or any other options to enhance the look.
  8. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    The minute thickness of the paint will not affect the cooling of the engine. I painted mine with flat high heat paint and it didn't make one bit of difference. There is some change in emissivity, which affects radiation heat transfer, but if anything, it is probably better for flat black paint than oxidized aluminum.
  9. Robert
    Agree with your point on emissivness, well taken. A painted surface is infinitely more useful for heat emission than corrosion. The effect of heat transmission of the paint is there, however small it may be, but it is there. One might say it is neglegible rather than non-existant. Point of view I guess. Besides, the painted surface will last longer and is easier to clean. Both benefits worth concidering.
  10. mike.
    mike. New Member
    BC, Canada
    aluminum has an emissivity of about 0.25, paint is usually around 0.9
    that's a big difference and means a painted bike will run a lot cooler (provided the paint isn't stupidly thick to stop heat transfer)
  11. DudeBozo
    DudeBozo New Member
    Lafayette, LA
    I painted mine with a thin coat of black high-temp ceramic engine block paint. I have used an infrared thermometer on it several times before and after and notice no change whatsoever. As mentioned in previous posts, keep the coat of paint as thin as possible.
    Robert, out of curiosity, where can I get information of the auxiliary air cooler? My neighbor has problems with his Suzuki running a tad hot.
  12. Robert
    I swiped mine off of ebay from a donor 83 turbo and a Brit 750. I looked up the physical dimentions of oil filter spin on plates in the JC Whitney catalog as they have a metric spin on adaptor that will work. I have no idea what to suggest for your buddies Suzuki but you are in luck. As I recall, most Suzuki's have spin on oil filters already so the adaptor plate for a cooler will be easy to score and install. Hook up with some appropriate size AN fittings and stainless lines and your golden (might cost a bit though, about $120 by my reckoning including the cost of the smallest air cooler, which if your lucky can be sourced at the wreckers). Oh yeah, the power steering cooler off of a more modern Ford would work nicely. TN ought to have scads of these and I'm sure you will find just what your looking for in a short time Bozo. Good luck on that one! Mike, your paint plug is just the kind if detail that makes these discussions worthwhile, keep it up!! Good thread all!
  13. DudeBozo
    DudeBozo New Member
    Lafayette, LA
    Thanks Robert. I'll get with him and see what we can come up with.
  14. mike.
    mike. New Member
    BC, Canada
    curious about the infrared thermometer, did you change the emissivity settings for the bare metal and then for the paint?
    just wondering because most them use as a default something between 0.9 and 1 but aluminum is far from a black body
    if you didn't change the emissivity settings for the metal it would give you a really off reading
  15. DudeBozo
    DudeBozo New Member
    Lafayette, LA
    LOL, being that I didn't even know there was a word called emissivity until today I would say not. However, if it has been off since I first took the readings, and I never changed anything on the thermometer, wouldn’t it have been consistently off? I mean, if it were always off say 20 degrees, would it matter if it were the same after I painted it as it was before? It may not be a true indicator of the specific temperature of aluminum, but it would be the same indicator of heat.
    I really don't know much about metallurgy but the head was painted from the factory, I just removed the old paint and added new. So, in the case of the thermometer, I have always been aiming at a painted surface.
  16. mike.
    mike. New Member
    BC, Canada
    paint has an emissivity usually around 0.9 so if the surface was actually 100 degrees the radiative temp would be 90 degrees (if you had the emissivity on the thermometer set to 1)
    aluminum has an emissivity of around 0.25 so if it was 100 degrees (and again you had the emissivity on the thermometer set to 1) then it would read as 25 degrees
    so you'd get a reading of almost 4 times higher with the painted surface than the bare aluminum if you didn't properly adjust the emissivity on the instrument, most cheaper ones don't have an adjustment anyway and just have a default around 0.9 or 0.95
    see all the stupid stuff you learn when you get a degree in geography? (and this isn't even getting into specific band emissivity or that the angle at which you hold the thermometer to the surface will affect the reading as it'll be looking at a different size area)
  17. RyanfromOhio
    RyanfromOhio Member
    Toledo Ohio
    I was going to powder coat mine.
    Decided against it due to cooling issues.
  18. DudeBozo
    DudeBozo New Member
    Lafayette, LA
    Wow, I'm glad I stuck with Marketing.... :)
  19. Ralf
    Ralf New Member
    Canada, BC
    Okay can I or can I not paint the engine? And if it's safe to paint how many coats do I use? And thanks to Robert about the oil cooling.
  20. Ralf
    Ralf New Member
    Canada, BC
    Is there a way to clean the engine up so it looks new without painting it?
  21. DudeBozo
    DudeBozo New Member
    Lafayette, LA
    AS I mentioned in my first post. I don't see a problem with a light coat on the engine head. I did mine, the average temp's here are in the 90's F during the dummer months. I do mostly cruising through town and a little highway driving. I have had no problems with overheating on my bike.
    As far as painting the whole block? My bike would'nt look good like that so I never tried.
  22. Robert
    I'm itching to put my engine back in! I want to test this whole thing out with my completely painted engine here in southern California. I'll be sure to post my experiences and data as I get it. More to follow (provided the sky doesn't fall).
  23. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    The block on my bike was completely bare oxidized aluminum, so I bought some flat black high heat paint and applied it with some artists brushes (no overspray that way). I also did the headers, which were rusty fom riding in the early spring when the salt had not yet washed away. No flaking or cracking in over a year of riding. In retrospect, I probably would have gone with the glossy stuff though.
  24. Robert
    Very impressive after a year of service. Recall the brand and product name?
  25. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    Tremclad is a product for the Canadian market, a very common brand of paint. Looks like it's a Rustoleum product. I used a pint can (or metric equivalent!) with some cheap brushes. It was actually a pretty relaxing exercise, in comparison to all the masking and overspray worries associated with aerosol paint. The only place it failed was on the turbo case, which runs near 800C, well above the 650C rating of the paint. Needless to say, the engine itself would be a pool of molten aluminum well below 650C, so the paint should be near indestructible.
