Front wheel not spinning so free — dual disc conversion
Discussion in 'XJ Technical Chat' started by xtmag, Mar 2, 2019.
  1. xtmag
    xtmag Member
    Rochester, MA
    i am in the process of doing a dual disc swap on my 1981 xj650 maxim. The donor bike is a 1982 xj750 maxim.
    I have the 750 forks installed and the front wheel mounted with twin rotors installed.
    Calipers are not on yet, still cleanin those up.
    Axle is torqued to spec (77 ft lbs) but the wheel doesn’t seem to spin as freely as I think it should.
    All spacers etc are in place, any ideas? Should there be resistance to the free spin when it is torqued to spec?
  2. Jetfixer
    One item do you have the speedo pickup aligned with the notch on the lower fork? And is it aligned with the wheel properly? This where I would check.
  3. robbo
    robbo Member
    uk
    had the same problem on my maxim when i had the wheel out.i turned the spacer on the axle the other way round and all good.
  4. xtmag
    xtmag Member
    Rochester, MA
    Yes this is in the notch, good idea!
    Another good idea! I’ll test it out.
  5. Praxeus
    Praxeus Member
    British Columbia
    Check your bearings.
  6. XJ550H
    are you using the spacers from 650 or 750?
    never mind the parts are the same.
  7. xtmag
    xtmag Member
    Rochester, MA
    Bearings spin freely but I suspect they are pretty old.
    Going to install new bearings, cheap insurance!
  8. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    While apart check the inner spacer is between the bearings and in good shape.
    Ive seen theese missing, damaged, or worn lots from bad bearings, it makes the bearings pinch together when the axle is torqued and they will fail quickly.
  9. xtmag
    xtmag Member
    Rochester, MA
    It’s in good shape. I knocked out the old bearings tonight. They spun but were stiff.
    New set comes Friday.
  10. jayrodoh
    jayrodoh YimYam
    Cleveland
    New bearings are good. FYI, it is possible to drive the second bearing in too far against the spacer causing the bearing to bind up and side load in your wheels. Removing the bearing is considered destructive to he bearing and you'll have to buy another set. BTDT ;) Just tap it in until it just touches the spacer. Too loose and the outer spacer will cause it to bind as well when you tighten up the axle. Think of the spacers and the bearing inner races as one piece.
    Pic attached to illustrate.
    Timbox, Ryengoth, xtmag and 1 other person like this.
  11. Fuller56
    Fuller56 Well-Known Member
    Jayrodoh, Very nice depiction of the bearings proper installation. Well done Sir.
    John
  12. xtmag
    xtmag Member
    Rochester, MA
    Ok bearings changed, just snug against spacer. It’s a little bit better, I guess it’s just the way it is!
  13. xtmag
    xtmag Member
    Rochester, MA
    On the caliper mounting bolts, there are 2 washers. A lock washer and a flat washer.
    Do these both go between the bolt head and the mount point or does the flat washer go in between the mounting point and the caliper?
  14. k-moe
    The flat washer goes under the lock washer, not the way you have it.
    jayrodoh and xtmag like this.
  15. xtmag
    xtmag Member
    Rochester, MA
    The brake pad shim, does that go on the piston side brake pad?
  16. XJ550H
    piston side
    xtmag likes this.
  17. xtmag
    xtmag Member
    Rochester, MA
    Ok I am an idiot. Forks were uneven by an 1/8th of an inch. I know I checked that at the beginning of this but it was late and a couple beers. Readjusting now but already spins better now that I have the forks loose.
  18. xtmag
    xtmag Member
    Rochester, MA
    Also, how much of the forks stick up past the triple??
  19. XJ550H
    top of upper tubes are flush with triple tree
  20. xtmag
    xtmag Member
    Rochester, MA
    I am putting 1982 XJ750 forks in there. Should it be even with the bottom of the adjustment dial?
  21. XJ550H
    yes right where it meets the upper tubes
    xtmag likes this.
