Correct oil for my XJ650?
Discussion in 'XJ Technical Chat' started by James Sampsan, Apr 1, 2019.
  1. James Sampsan
    James Sampsan New Member
    Richmond
    Ive read that 20W-40 is the way to go but also that 20w-50 works as well. I just want to double-check.
    My local Walmart carries Mobile 20W-50, will that work or should I go to AutoZone/O'Reillys/an auto parts store?
  2. Nambro
    Nambro Member
    Colorado
  3. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    20W40, 15W40, 20W50 are fine unless you live somewhere really, really cold all the time or really, really hot all the time. I've used 20W40 here in Michigan. What is MORE important is that you change the oil as required. I do mine every 1,500 miles with out fail. That is the reason I have the spin-on oil filter adapter. I've had my bike since 1985 and put on over 35,000 miles on it with 0 oil/clutch related problems.
    D
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
  5. k-moe
    The viscocity should be matched to the average ambient air temperature during your riding season (chart added to the first post in the above thread) .
    The certification should always be JASO MA, MA1, or MA2.
