Tackling starter rebuild this weekend!
Discussion in 'XJ Technical Chat' started by Lanny, Apr 4, 2019.
  1. Lanny
    Lanny New Member
    Minnesota
    Okay, doing the starter rebuild this weekend if my rebuild kit arrives. Just have one question. When I’m lightly sanding the commutator. (3000 grit) do I sand it down it’s length or in a circular motion, or does it make a difference? Thanks in advance.
  2. k-moe
    Around the axis. Be careful, and make sure that all you are doing is removing corrosion and any light scoring. Sanding too far will require re-cutting the mica between each bar. Oftentimes you only need to clean the commutaor with a hard art eraser.
    Lanny likes this.
  3. Lanny
    Lanny New Member
    Minnesota
    Thank you. The commutator doesn’t look bad actually.
  4. JetmechMarty
    JetmechMarty Active Member
    Coldwater, Mississippi
    YouTube should have plenty of videos on rebuilding a starter or any dc electric motor or generator. Even an aviation manual can tell you the correct way to bed the brushes.
    How many on here have used a growler? There used to be one on the bench in every auto garage.
  5. Rooster53
    North, FL
    No wonder those mechanics couldn't turn out quality work - a bunch of drunken morons.
    jayrodoh and JetmechMarty like this.
  6. JetmechMarty
    Growler
    chacal and Rooster53 like this.
  7. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Where I'm from, a growler is a big ol jug of beer!
  8. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    where i'm from its a pork pie.
    stu
  9. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Good tip!
    Put the shaft end near the commutator in a drill press on low, use a very fine file, cleaning often, to even out the contacts, then hit with scotch brite.
    After, use a pick to clean out the grooves lengthwise, smidge of low temp grease on busings and washers... Presto! :)
  10. JetmechMarty
    I don’t think you should put a file to it. Just use fine garnet paper.
    Use an ohmmeter to verify none of the commutator segments are shorted to the shaft.
  11. Colin 85 700
    Thunder Bay, ON
    Especially if your changing brushes, you want to even the commutator as mentioned above.
    It wears convex. ) ( emery paper wont correct this and its harder for the brushes to seat, plus they dont make proper contact. ]) ([ Filing solves this, giving you more power and longer brush life ][ ][
    Just dont forget to clean the groves, they will build up with copper dust and short out the starter.
    Then, rub wit scotch brite, blow dust out, like new. :)
  12. Colin 85 700
    Thunder Bay, ON
    To add, if you are ever in a starter, when you are done its a good idea to hook up the starter NOT turning the engine and spool it up a few times NOT under load, this not only tests your starter before you put it in, but better seats the brushes and shims etc you just messed with.
    (Use Booster cables on the floor even)
  13. Colin 85 700
    Thunder Bay, ON
    When i recently checked my starter, it barley had black marks on it, i just rubbed it with scotch brite quick and hit it with an air gun... Done
  14. JetmechMarty
    I believe emery cloth is a no no, IIRC. Garnet paper because it isn’t conductive. There are quite a few ways to ruin the commutator. That would be a shame if it just needs a little cleaning.
  15. k-moe
    Correct. Emery is made from naturally occuring form of aluminum oxide, but often silicon carbide is substituted. Both conduct, so having any bits left in the starter is a not-so-good thing.
    Colin 85 700 likes this.
  16. Colin 85 700
    Thunder Bay, ON
    Emery cloth, garnet paper, silicon carbide tungsten alluminum oxide alloy carbon impregnated whatever...
    All im getting at is that any form of sanding is never even, if scotch brit cant clean it, a super fine file with the armature rotating is the only way to get an even, flat surface.
  17. k-moe
    Unless you ahdere to standard practice and glue the paper to a flat block.
    You can (well I can, you might not be able to at home) turn it on a lathe, which will eliminate the possibility of your hand not keeping the file (or block) flat to the armature.
    Many ways to skin a cat, and so long as one takes care in setting things up all will be well.
    Checking the armature for linear flatness with a straight edge first is a good practice as well.
    Most of the time none of that is necessary though. Carbon brushes are very soft, and starter motors only see intermittent use, so little if any wear will occur on a rarely ridden motorcycle.
    cgutz likes this.
  18. XJ550H
    crocus cloth is suitable for use
    "Unlike sandpaper or emery paper, crocus cloth is a super-fine, cloth-backed soft abrasive that doesn't "shed" particles during use, and is just the thing for burnishing and polishing of copper electrical contact, like the alternator rotor and starter motor commutators." XJ4ever.com
  19. Lanny
    Lanny New Member
    Minnesota
    Well, I finished the rebuild and installed it and hit the start button and got sparks and a poof sound. Uggg! Guess I will be looking at ebay today for a new/old starter.
