Need parts for 1982 XJ650 Maxim
Discussion in 'XJ Technical Chat' started by Chris Capstick, Apr 7, 2019.
  1. Chris Capstick
    Chris Capstick New Member
    Woodside
    I am told there is a very reliable and solid parts dealer on here.
    Here's the list:
    4 intake boots
    Crank case gasket
    4 carburetor gaskets
    1 petcock rebuild kit
    1 air filter
    Thanks a bunch. I will keep an eye out for a response.
  2. Chris Capstick
    Woodside
    Oops,
    Also need:
    Gear shift crank case oil seal....(not sure that's what to call it) the seal around the arm that holds the shifter.
    Thanks !
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Hey Chris, see that button up at the top right corner? It's a link to XJ4EVER. That's the "reliable and solid" parts dealer you've heard of. Or you could start a conversation with user @chacal . He's the guy at XJ4EVER. He'll set you straight on what you need and what it is called.
  4. Chris Capstick
    Woodside
    Thanks Matti ! Do you think @chacal will respond to this notice or I need to start a chat some other way ?
    Tnx again
  5. Nambro
    Nambro Member
    Colorado
    Click on his name and then the "start a conversation" option to send him a private message.
  6. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    He responds to PM but may take him a few hours to see it and respond. Email is another option Info@xj4ever.com. If you do the catalog research first and get the part numbers together he will respond a bit faster on quoting.
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
  8. Chris Capstick
    Woodside
    Sticker shock for sure, but Tnx !
  9. Jetfixer
    Xj4ever is the best source hands down ,yes some items are pricey , but also realize that there is a dwindling supply of new parts . I restored a 71 VW beetle still can get most parts , been to plenty of car shows and swap meets seen junk throw away parts for sale with high prices , when new can be bought for slightly more money. Best moto buy the best cry once....be aware alot of item on eBay may seem like a deal but may or may not fit on the other hand chacal sells OEM or pattern parts and these will fit!!!!
    cgutz likes this.
  10. cgutz
    cgutz Well-Known Member
    SE South Dakota
    There are so many "versions" of each model, that only Xj4ever can be depended on to get you the right part, at a fair price, and fast service.
    I tried the ebay thing for rear brake shoes...supposed to fit...didn't....didn't save any money....
  11. Chris Capstick
    Woodside
    Copy that and thanks! I think I’ll just cry the once...!
    Jetfixer likes this.
