Cleaned carbs now not start
Discussion in 'XJ Technical Chat' started by Barry 363, Apr 26, 2019.
  1. Barry 363
    Barry 363 New Member
    De556gj
    Hi there having a nightmare with this I have a xj650 trike was running lumpy on tick over but wood rev up fine but carbs was leaking so pulled carbs off stripped them down and cleaned them out had new jets new needles new mixture screws the lot now she wo t start if I spray carb cleaner in air filters it will splitter n start on tick over but dies when you think about throttle plz help
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Did you replace the jets, needles and mixture screws with exactly the same parts?
    Some of those pod filters can block off the passageways if not located properly. Are they the right carbs for the engine?
    Just trying to get a bit more info so that others can help out too.
  3. Barry 363
    De556gj
    I got a rebuild kit mate for the xj650 jets was same as for mixture screws the was different the treads was coarser so clean n used old ones needles looked these as I used the needle tubes that came with the new needles
  4. Barry 363
    De556gj
    Needles looked the same so I used them and the brass tube that needles sit in
  5. FJ111200
    I'm no expert on the 650 models but I do know that carb parts varied between the US import and European models.
    Find out what the engine number of your bike is, the first three number and letter part which is stamped onto the right hand engine case above the clutch case, and then make sure you've got the right parts.
    I use this website https://www.cmsnl.com/yamaha-xj650_model16829/ for all my references.
  6. Timbox
    Sure wish you had some pics with this. From my past I can tell you that if you didn't take those carbs to "Church" than they are not clean. Stripping them all the way, to include taking the throttle shafts out is a proper cleaning. If not, you can and will run into issue with revving and popping from them. Carb cleaner on the throttle shaft seals will mess them up and anything else that is rubber will be dried and start to crack.
    https://www.xjbikes.com/forums/threads/in-the-church-of-clean.14692/
    That is the link you need to look at if you have not read it before. When I first started with these wonderful XJ bikes I pulled the carbs off six times before I got mine right. I just want to make sure you learn from my mistakes. ;)
    Simmy likes this.
  7. k-moe
    The only thing that varied on non-U.S. bikes is the fuel jetting. All the other parts are the same.
  8. k-moe
    Did you replace the float needles and seats?
    Did you set the fuel level in the carbs? That is a must-do if you install new float needles.
    Setting the fuel levels
