XJ 550 Maxim voltage rectifier connector?
Discussion in 'XJ Technical Chat' started by jtricer1973, Apr 27, 2019.
  1. jtricer1973
    jtricer1973 Member
    Mississippi
    Hey folks. The connector under the seat of my 550 that connects the voltage rectifier to the harness is burnt. Where can i find a replacement? I need both the male and female. Its burnt where the red ignition wire is. Ive been working on this thing forever and just found this.
    xj4ever
    HCP9336FMWHT Aftermarket white plastic FEMALE CONNECTOR SHELL, 8-place, rectangular, with a male latching peg, used on all of the following circuits listed below. Accepts the HCP9360xx male flat-blade terminal. Each:
    HCP9336MFWHTWE Aftermarket white plastic MALE CONNECTOR SHELL, 8-place, rectangular, with a female latch-peg receiver and side "ear" tabs, used on all of the following circuits listed below. Accepts the HCP9361xx female flat-blade terminal. Each:
    he also sells the pins or blades in the correct size for the wires used
  3. jtricer1973
    jtricer1973 Member
    Mississippi
    Where and how do I find him
  4. jtricer1973
    jtricer1973 Member
    Mississippi
    Ok, found it. Thanks man
    XJ550H likes this.
  5. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Be sure to go over the rest of you wiring harness to clean and grease all connections, bulb sockets, etc as well as cleaning all ground connections to the engine or frame. If they got hot there is a reason for it. Once repaired I recommend testing your charging system for proper operation.
  6. jtricer1973
    jtricer1973 Member
    Mississippi
    I suspect that something is wrong with the charging system. The battery in it nowis not a year old and is shot. Have a new one, just gotta get it charged.
  7. XJ550H
    check voltage at battery at 2000rpm and 3500rpm it should nor exceed 14.8 volts. and should be charging around 14 .6 volts
    what kind of battery do you use ? if it is a lead acid battery you have to check the fluid level and refill it with distilled water when low.
  8. jtricer1973
    jtricer1973 Member
    Mississippi
    Well, i'd check the voltage but can't even get the damn thing to start! Started several times the other day, ran for a few minutes then dies eventually not starting again for a while. Runs good for a few minutes though when it does start.
  9. XJ550H
