XJ650R carb and running issue
Discussion in 'XJ Technical Chat' started by Austin Ramey, Nov 15, 2018.
  1. XJ550H
    does it have a vent?
  2. Austin Ramey
    Austin Ramey Member
    Modesto CA
  3. Austin Ramey
    Austin Ramey Member
    Modesto CA
    Yes
  4. Austin Ramey
    Austin Ramey Member
    Modesto CA
    I did the cold run like you asked and same issue. I did pay mower attention to the hesitation is around starts about 2000 RPMs to 3000. But if you get on it it’s not there. I took volt readings at 2000RPMs and it was 14.15 VDC and 3000RPMs was 14.26 VDC.
    I have a thought and taped half of my air filter with duct tape and went for a ride. My hesitation went from 2-3000 RPMs to 4-5000RPMs. Improvement. Came back and taped up the filter a little more than 3 3/4 of the way. Went for a ride and essentially it was gone. Still has a little studded at higher RPMs but to be expected since the carbs are set to a different air flow.
    I’m thinking I need to put bigger jets in. I am currently running the stock jets from alphamoto #40 and #110. Do you have any suggestions what I should up the size to?
  5. Polock
    what kind of air filter is on it?
  6. Austin Ramey
    Austin Ramey Member
    Modesto CA
    UNI high flow. K&N style
  7. Austin Ramey
    Austin Ramey Member
    Modesto CA
    Original intake set up as well 1 big filter. No pods
  8. Polock
    get yourself a oem filter, i think your problems will go away
    i used two layers of UNI foam on a stock frame and had those kinds of problems
  9. Austin Ramey
    Austin Ramey Member
    Modesto CA
    I will try that. Thanks
  10. k-moe
    I have a K&N.
    It sits on my shelf of mistakes.
  11. Austin Ramey
    Austin Ramey Member
    Modesto CA
    Does anyone know who sells them? Besides eBay
  12. Austin Ramey
    Austin Ramey Member
    Modesto CA
    What filter do you recommend? The stock Yamaha one or Emgo makes one as well. They say it meets and exceeds OEM Paper filters
  13. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    I'm curious on Emgo opinions as well. The OE filter I have is beat up pretty bad. So far I've been pleased with Emgo quality, but air filter elements can cause you tuning headaches if the media does not have the same flow restriction as OE.
    Austin Ramey likes this.
  14. XJ550H
    emgo works well
    k-moe and Austin Ramey like this.
  15. Austin Ramey
    Austin Ramey Member
    Modesto CA
  16. k-moe
    IIRC EMGO makes the OEM filter too.
    Ryengoth and Austin Ramey like this.
  17. Austin Ramey
    Austin Ramey Member
    Modesto CA
    Ok thanks for all the help to everyone here. I just need a little bit more advice. I’m going to start over on my carbs now. Can someone please tell me a step by step procedure for the carb set up from scratch. When I set the idle mixture screw 2.5 full turns out. Where should I set my idle screw at etc. and how should I proceed from there.
