What happened!
Discussion in 'XJ Technical Chat' started by Edwin Portillo, Jun 8, 2019.
  1. Edwin Portillo
    Edwin Portillo New Member
    New Jersey
    Was riding last night when my rear brake pedal snapped back at me and when I got home I noticed this was how it looked xj750 maxim 82. [​IMG] [​IMG]
  2. Toomanybikes
    Tsawwassen bc
    Can’t see the pics Edwin
  3. Edwin Portillo
    New Jersey
  4. Toomanybikes
    Tsawwassen bc
    Retaining bolt for the brake drum arm fell out “someone” didn’t install a cotter pin in the bolt after reassembling the brakes. It’s a special bolt that has a shoulder on it and a cotter pin hole at the end.
    It’s available from your local Yamaha dealer and flat washer, lock washer and nut and of course cotter pin.
  5. Edwin Portillo
    New Jersey
  6. Edwin Portillo
    New Jersey
    Do you see that one part that seems a bit bent, is that normal?
  7. Toomanybikes
    Tsawwassen bc
    Do you mean the brake rod wrapped around the axle ;)
  8. Edwin Portillo
    New Jersey
    Haha yea I need a new one huh
  9. k-moe
    I think it's time to set riding aside and thoroughly inspect everything on the bike.
    Timbox likes this.
  10. Polock
    go play the lottery, your lucky
  11. Edwin Portillo
    New Jersey
    I agree I just got those drums replaced, next is stainless brake lines. Im going to have a word with my mechanic cause it could have been worse luckily I was 2 blocks from home o_o
  12. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    I replaced shoe's recently, and lost the cotter pin. [ left out].-- I'm going to the cotter pin store today!
    your post awakened me. Thanks, and sorry for your troubles .
  13. chacal
    We have all the parts you need in stock, but can't help out with a new mechanic, you'll be on your own for that...........
    Jetfixer, Franz and Edwin Portillo like this.
  14. Edwin Portillo
    New Jersey
    Thanks for your help ill be ordering everything through chacal the XJ legend
  15. Timbox
    If you had a "shop" do that and not a "friends shop" I would be hesitant to ever go back to them. You are lucky, could have been much worse. Glad you are okay and now to finding parts and making sure the inside of the rear hub is okay?
  16. Edwin Portillo
    New Jersey
    This mechanic has been great from the start, is it possible perhaps it was knocked off by something? He's more than double check my bike from the start and he's been working on it the past 4 years. I'm greatful to be alive! To be honest no one else in my area will even TOUCH my bike because of its age. Can I get a list of the parts I'll need?
  17. Toomanybikes
    Tsawwassen bc
    Just ask @chacal he will get you all the right bits just show him the part number I posted and your picture. And The rod did not survive so if Len doesn’t have one I do.
  18. XJ550H
    i would bring the parts bill to the mechanic big oversight on his part
  19. k-moe
    There is no way that failure can occur from anything but neglegance on the part of the last person to work on it.
    Everyone makes mistakes, but that one should never be made.
