XJ700 Maxim doesn't start
Discussion in 'XJ Technical Chat' started by Quinten Michael Permenter, May 23, 2019.
  1. Quinten Michael Permenter
    Quinten Michael Permenter Member
    Indianapolis
    Perfect!!! We got her running!!!! She starter right up and reved up all the way but when I went to slide the clutch lever to the right she stayed up super high. Any suggestions?
  2. k-moe
    Make sure that you didn't reverse the throttle and enrichment cables when you installed the carbs.
    The throttle cable connects to the linkage between, and in front of, the #2 and #3 carbs.
  3. Quinten Michael Permenter
    Indianapolis
    So here is a little update again, I think it was the throttle cable that wasn't set right on the carb and the throttle was stuck open and so that is why it reved. So I adjusted that and it lowered it to a good idle speed but now it is jumping back and forth or reving itself high and low and when I try to give it gas, It revs up and then putters out.
    What should I do from here?
  4. XJ550H
    is the linkage hanginu up on the head?
    check the ignition system
  5. Quinten Michael Permenter
    Indianapolis
    I had great spark out of all of the coils. Could it be that I need to sync the carbs after it all? Or what else would cause the rpm to rev up and down so much???
    Is there a mixture screw? Or an idle adjustment screw?
    thanks for the help guys
  6. k-moe
    Out of synch carbs can cause the idle to fluctuate.
  7. Quinten Michael Permenter
    Indianapolis
    Okay, so the carbs are synced and it evened everything out a ton!
    But when I give it gas in first gear, it putters out and doesn't move. I think this is due to the fact that i bought it and it had pods on it and the air to fuel ratio isn't right. Would this be a correct assumption? I know the jets are clean because I just cleaned them. But if I am right and it isn't running right because of the wrong air to fuel, is there a way to change this without changing the jets? Or if I have to change the jets, what size should I go with?
    Thanks for the help!
