Master brake cylinder
Discussion in 'XJ Technical Chat' started by Plumper, Jul 7, 2019.
  1. Plumper
    Plumper Member
    Taber
    IMG_8230.JPG IMG_8231.JPG So I managed to get those screws out and when I looked inside I found this ugly mess, is that rubber piece suppose to look like that? And what's the best way to clean all that gunk out of there? I am planning on replacing the lines and doing a good brake clean over the winter but now that I found this I should clean it up a bit for the summer
    clean it rebuild it
    that rubber thing mounts on cap should not be like that
    there is a recent post on doing this someone will provide a link
  3. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    I had the same issue this past winter. Redid the MC and caliper. Cleaned everything up with my ultrasonic and rebuild kits.
  4. k-moe
  5. Plumper
    Plumper Member
    Taber
    I did read that brake line thread and I am planning on switching to ss lines, the bike was braking fine but the sight glass is all messed up so you can't see the level I was just checking it out of curiosity to see how full it was and found that mess
  6. k-moe
    @chacal has replacement sightglasses (and everything else). Start a conversation with him.
  7. Plumper
    Plumper Member
    Taber
    Sweet I didn't know you could replace just the glass, I'll send a message to him found a pretty sweet little video on bleeding and replacing brake fluid so that pretty much answered my future questions seems pretty easy to do
  8. k-moe
    It is pretty straightforward. You have one of the easier systems to work on.
  9. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Unless you really like a hard feel I would not use stainless brake lines. I put them on my XJ700N when I completely rebuilt the front brakes and I don’t like the hard feel. They work well but I just don’t like the feel. My other bikes have standard lines, work just as well, but have a softer feel. I am not an aggressive rider so standard, softer feeling brakes work for me.
  10. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Site glass replacement was easy for me and the sweet part was Len sent instructions
  11. Plumper
    Plumper Member
    Taber
    What do you mean by hard brake like it's hard to pull or to touchy? I don't mind how my brakes feel now with the old ones
  12. Plumper
    Plumper Member
    Taber
    IMG_8235.JPG Check these out, took it out of my 83 magna parts bike, looks like brand new on the inside and it fits perfectly on top my cylinder
  13. k-moe
    Braided stainless lines won't expand when you apply the brakes. Rubber lines do, which give a softer feel (and reduces the maximum braking potential of the system). IMO if you ride anywhere near modern traffic you should upgrade to braided lines.
    They aren't hard to pull, or touchy. They just feel different because the lines aren't expanding as you pull the lever.
  14. Plumper
    Plumper Member
    Taber
    O ok, I'll give em a try see if I like em,
  15. Plumper
    Plumper Member
    Taber
    Dos the rear drum brake take brake fluid or just calipers
  16. XJ550H
    it is mechanical a rod runs to the pedal no fluid and it takes shoes if it is a drum
    I am guessing from handle bars and seat it is an 82 maxim
  17. Plumper
    Plumper Member
    Taber
    Yup it is 750
  18. Plumper
    Plumper Member
    Taber
    I was pretty sure there was no fluid but thought I'd check, thanx
  19. Plumper
    Plumper Member
    Taber
    I really didn't wanna ask this but Google didn't tell me, how full do I fill the cylinder? To the lower line or right full,
  20. XJ550H
    above the line enough so it does not spill out when cover and diaphragm is installed. but low enough so it should leave a little air bubble in the window so if you look at it when riding you see an air bubble and know you have fluid in there.
    no problem asking about the rear brake drum better to ask and learn
    this ain't FB we wont rag on you for not knowing
  21. Plumper
    Plumper Member
    Taber
    Haha thanx dude, I'm glad I don't have to read through 47 "get your girlfriend to show you" responses to get a real answer, like you said better to ask and learn then not, hahaha thanx
  22. XJ550H
    get your girl friend to show you:) there we are done with that :cool:
  23. Plumper
    Plumper Member
    Taber
    I wanna get new mirrors what size thread is it? 82 750 maxim
  24. k-moe
    M 10 x 1.25. Throttle side mirror has a left-hand thread.
    There are adapters available if you need to have a right-hand thread on the throttle side, but they will raise the mirror height, and you'll need onw for the clutch side too.
