Sealed beam retaining clip xj650 maxim
Discussion in 'XJ Technical Chat' started by MaximusXJ650, Jul 12, 2019.
  1. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Does anyone know how the retaining clip is held on?
    It looks as though it is spot welded on and mine has come off from two places so I'm now riding with electrical tape over the lens and fastened behind the headlight to hold it in place
  2. Toomanybikes
    Tsawwassen bc
    Show us some pics of what you speak. And later models had replaceable H4 bulb.
  3. XJ550H
    the part that holds the glass to the crome ring
    screws and springs with nylon nuts 15, 16, 17 adjusters
  4. Toomanybikes
    Tsawwassen bc
    I think he’s talking about the ring #7 has tabs broken off.
  5. XJ550H
    I think so too.
  6. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    No it's not that. It doesnt look to be in that diagram.
    It's a thin stainless steel ring that sits on the lip of the glass and holds the glass to the main headlight.
    Chacal told me its tack welded on
  7. XJ550H
    photo please
    part 6 is outer ring attachecs to bucket
    part 7 holds glass to part 9
  8. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Its 10pm and the bikes locked up. I'm up early for a morning ride so will get a pic before I leave
    XJ550H likes this.
  9. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Here's the clip I'm talking about
  10. Toomanybikes
    Tsawwassen bc
    Something missing, headlight should not protrude that far out of the bezel.
    I’ll post a pic of all the parts that should be there.
  11. Toomanybikes
    Tsawwassen bc
    This is what’s broken??
  12. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    No, it's a different clip
  13. XJ550H
    0717191838.jpg 0717191843.jpg this clip holding #7 to #9 retaining headlight in 3 places w/screws.
    I have more photos of other parts of the rim adjuster connects inner holder to bucket ring # 15 through hole in #6 through #16 spring to bracket on #9 with nylon "nut" #17
  14. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Its this bit, where you see the 2 small bumps. They are tack welded and mine has separated on two of the three brackets. But as I mentioned Chacal has already answered me.
    Toomanybikes and XJ550H like this.
