What's with WHEEL SPIN in nuetral? xj750 Maxim
Discussion in 'XJ Technical Chat' started by 750MaximSeattle, Jul 11, 2019.
Tags:
  1. 750MaximSeattle
    750MaximSeattle Active Member
    Seattle, WA
    With bike on center stand, when the bike is started after sitting cold then the rear wheel spins slowly until bike warms part way up (1-2 minutes). My previous Maxim's tended to do this. Don't know the cause, but I use Castrol 20w50 4T (motorcycle engine oil for these "wet" clutches) and just changed both oil and filter. Previous oil change was done a year ago, and I rode just over 1,000 miles between oil changes.
    A potential buyer wants to know.
  2. squidx85
    squidx85 Member
    South Dakota
    I think it's just an effect of the viscosity of the oil on adjacent moving parts. If you look at a 4wd pickup, if the transfer case is in rwd, hubs unlocked, on mine even with synthetic oil, the front driveshaft still spins a little. You can grab the shaft by hand and stop it, or spin it when the truck isn't moving.
    Franz and 750MaximSeattle like this.
  3. Toomanybikes
    Tsawwassen bc
    Totally agree with @squidx85 . Cold thick oil will want to turn the gearbox. Both my xj’s and my cb900 do this. Also proves that brakes don’t drag and all bearings in good shape.
  4. XJ550H
    it is normal bikes do it more so when oil is cold.
    I can feel the drag in neutral when I try to roll bike before it is started when its warm all gone
    Jetfixer and 750MaximSeattle like this.
  5. Franz
    Franz Well-Known Member
    Scotland UK.
    Is this the basic principle of torque convertors I wonder?
  6. k-moe
    Essentially.
  7. Franz
    Scotland UK.
    So the hydraulic forces are much stronger in a torque converter. it is the same principle as pascals law?
  8. squidx85
    squidx85 Member
    South Dakota
    I think pascal's law is 'the same pressure exists everywhere in a confined system'. Explains how your brakes use a hydraulic form of mechanical leverage, ratios of surface area. I have a hard time picturing how a torque converter works internally, but what I've always heard is they're like 2 fans aimed at each other. Change the blade pitch and you can actually multiply torque with a fluid coupling, which I guess torque converters do.
    Yes, I am a nerd, but I'm also a high school dropout.
    Franz and chacal like this.
  9. JBurch
    JBurch Active Member
    Owego, NY
    It's fluid drag, even though it's in neutral, the input shaft is spinning and thus all the gears within the transmission, it just shows how slippery the oil is not.
    the vanes inside a torque converter are actually turbines, one is stationary, the other moves, fluid under pressure moves across the stationary blade to the rotating blade causing it to move, angle of the fins alters your torque multiplication and thus your "stall"
    Franz likes this.
  10. Cattleman XJ
    Cattleman XJ Member
    Texas
    Is the potential buyer new to motorcycles?
    Every bike I’ve ever had had some rear spin in neutral when on a stand
  11. XJ550H
    only people who use centerstands would know that:)
  12. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Mine doesn't spin in neutral, you make me worried ha ha
