XJ550 seca/maxim wiring harness
Discussion in 'XJ Technical Chat' started by AFORSTER, Jun 12, 2019.
  1. AFORSTER
    AFORSTER New Member
    gateshead
    Hi,
    New here, just got an xj550 seca project on the go. Wiring was a mess so bought a new harness.
    In my haste i didn’t realise I’d bought a harness for an xj550 maxim.
    My question is, is there much/any difference between the harness’ ?? Or should I look at buying the correct harness
    Adam
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    Interesting question.. I expect in could be made to work. The 'muricans should know for sure, one will be along in a minute or two ;-)
  3. a100man
    Bedford, UK
    Blimey, I was wrong. Best thing I can suggest is to check out this link to the interactive 'Seca' diagram and cross reference to the Maxim loom you have.
    Note that by using 'mouse over' you can even see where some wiring elements are supposed to 'live' on the frame. We are indebted to the guy that made this!
    Cheers
  4. XJ550H
    seca has a fuel guage, volt meter, and 2 directional light indicators Seca does not have a separate bulb for license plate light the maxim does. that's the only things different between the 2 harnesses as far as electrical items.
    I do not know if the harnesses are the same physical size. I will look into it this weekend on Saturday. I have both harnesses on my bench
    The World’s Greatest XJ550 Seca Wiring Diagram:
    http://www.frankjohansson.com/stuff/xj550/XJ550ElectricalDiagram.html
    Franz likes this.
  5. XJ550H
    would have been here sooner just saw the post.
    the "parts" are all in the same location on the frame of the Maxim and Seca. but there is a slight difference in the frame Maxim is 100 mm longer.
  6. XJ550H
    on the maxim the turn indicator bulb grounds through the opposite blinker bulb than the direction you are turning. the 2 seca turn indicators ground to ground
    another thing is that the blinker connector pins can be a smaller diameter that the maxims.
  7. AFORSTER
    AFORSTER New Member
    gateshead
    Thanks so much for all your help, this clears things up loads! I might be able to make it work!
    Cheers,
    Adam
  8. XJ550H
    I must have sold the maxim harness but all the parts are in the same location on a maxim as a seca here is a dimentional layout.
    seca has 2 horns and tail light connector is different
    from headlight connector (without extendor to voltage regulator is 56 inches . zero point on drawing is the right controller connector, if you need more detail just ask I can photo harness at measure points and go deeper into all the connections
    chacal likes this.
  9. VinceD67
    VinceD67 New Member
    Ottawa, On
    Hi does anybody have pictures of the wire connectors for the start cut-off, sidestand and headlight relays. i am re-doing the wiring on mine and the diagrams i find dont tell me where the wires go in the connectors
    really appreciate it.
    Thx
    Vince
  10. XJ550H
    I do assume you are asking about a 550 seca or maxim
    this link helps you ID relays and the location on bike
    from above
    Starter/Ignition cut-off relay (no color): front of coil rear mounting bracket.
    Sidestand (kickstand) relay (blue): left side, behind rear frame cross tube. at tool tray
    Headlight relay (yellow): behind ignition coils, behind flasher canceller.
    I will get you some photos too.
  11. XJ550H
    flasher relay connector
    starter cut off relay connector notice light blue wire
    sidestand relay
    sidestand switch connector near battery wire
    head light relay
  12. AFORSTER
    AFORSTER New Member
    gateshead
    Thanks for the help, I've been tackling a problem on my main bike. Getting back into the XJ tomorrow so this will help massively!
  13. VinceD67
    VinceD67 New Member
    Ottawa, On
    thanks a lot!
