Turn signal bulb question
Discussion in 'XJ Technical Chat' started by PepNYC, Jul 21, 2019.
  1. PepNYC
    PepNYC Member
    Charlotte, NC
    This is probably a simple answer but I'm just not sure so I figured I'd ask. I have a 1993 xj600 seca II. When the bike is on, key just on or actually running, are all the signal lights supposed to be on steady? I ask because my front ones stay on with my headlight but my rear only come on when I hit the turn signal. I'm thinking this is right because the fronts have a dual filiment 1157 bulb. One stays on the other is for the signal. The rear ones are single filament, 1156, which only acts as turn signals but don't stay on all the time. Sound about right? Funny thing is I've had this bike for 5 years and never even noticed. Thanks all.
  2. mlew
    Correct the front uses a dual filiment bulb and the rear a single.
    I have changed the rear to dual filiment on all my bikes. More light is more visibility. Fitting a 1157 socket in there is not hard.
    Timbox and PepNYC like this.
  3. PepNYC
    PepNYC Member
    Charlotte, NC
    That's exactly what I was thinking but wasn't sure if it could be done. Where did you get the sockets?
    Kinda silly to me that they'd have running lights in the front only.
  4. mlew
    I got the sockets from a auto parts store. They need to be metal just like the original. I did have to cut the mounting tab off the original and solder it to the new one. Also had to drill the pipe in the signal housing bigger to get 2 wires in. Ground was the housing just like it was originally.
    PepNYC likes this.
  5. mlew
  6. PepNYC
    PepNYC Member
    Charlotte, NC
  7. Rooster53
    North, FL
    I think there is a consideration of being legal as in yellow running lights on the rear are not legal in some states.
    PepNYC likes this.
  8. PepNYC
    PepNYC Member
    Charlotte, NC
    Good point. They may have to be red.
  9. mlew
    Its not too late, give them a call and see if there are rooms available. Camping is an option too.
    PepNYC likes this.
  10. mlew
    I never looked to see if is legal but red lenses are available if needed.
    PepNYC likes this.
  11. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    NC GS 20-129 says it has to be red. Not that you can't have red AND amber, but it has to be red for tail and for brake.
    PepNYC likes this.
  12. mlew
    Well I guess both my XJ11s have been illegal for the past 10 years. They never said anything about it during inspections. I'll leave the amber lenses on until someone says something about it. My XS11 has red lenses so its OK.
    Rooster53 and PepNYC like this.
  13. Ryengoth
    Wilmington, NC
    If it's OE equipment they won't say anything since it was imported under DOT guidelines at that time. If it's obvious that it's been redone with newer equipment they could say something. I doubt they'll fail it unless it's blue or white. Wake can be a pain in general, though. The statute says rear tail lights and brake lights must be red. As long as the amber is just turn signal it should be fine.
  14. mlew
    Nope, I have amber lights in the back for running and turn signal . They are in the OEM stock housing. Since the bikes are old enough here in NC they don't need inspections anymore so they will never fail it.
    They get ridden all the time . They will stay as they are.
    A few weeks ago I spent a day riding with the local police and nothing was ever said. It was a police sponsord event where each participant was assigned an officer to follow them and critique their riding style and abilities. It was quite fun actually.
  15. PepNYC
    PepNYC Member
    Charlotte, NC
    How old does a bike have to be to not need an inspection?
  16. Ryengoth
    Wilmington, NC
    35 years is considered antique if memory serves, which does not require an inspection.
    PepNYC likes this.
  17. Ryengoth
    Wilmington, NC
    As an aside, if you are applying for a title due to loss title or no signed transfer from the owner, the bike must be inspected by NC DMV license and theft bureau. The equipment will be checked and reviewed for operation. The VIN will be verified. An indemnity bond must be secured by your insurance company (or you with cash at the DMV) for the value of the bike. In my case the 1982 XJ550 is $250. After that I don't believe it needs an inspection, but you may still have to go to an inspection station to get the electronic filing completed so you can renew. I've never owned an antique auto.
    PepNYC likes this.
  18. PepNYC
    PepNYC Member
    Charlotte, NC
    Aww man. Mine is a 93. Got a ways to go yet.
  19. XJ550H
    in NH it is 25 yeara old but if you want antique status you need to get an antique plate.
    BUT can be Used ONLY for exhibitions, club events, and public events.
