1983 xj750 k manifold vacuum
Discussion in 'XJ Technical Chat' started by Ken Madden, Aug 24, 2019.
I'm looking for the average manifold vacuum level I should be seeing
  1. How many inches of mercury
    0 vote(s)
    0.0%
  2. Inches of mercury
    0 vote(s)
    0.0%
  1. Ken Madden
    Ken Madden New Member
    USA
    Can anyone tell me the average manifold vacuum level I should be seeing on my carbs?
  2. Toomanybikes
    Tsawwassen bc
    Once they are even as idle is 1050rpm 10-12
  3. Ken Madden
    USA
    I'm only seeing 7. Might be the crappy gages I bought. The bike idles great
  4. XJ550H
    you are looking for equal or as close to equal after sync.
    it will be different on different gauges.
  5. k-moe
    Actually it shouldn't be, unless inexpensive dial gauges are being used.
    OP, here's the thing. Yamaha didn't give a spec for manifold vacuum since there are no vacuum accessories other than the petcock. You also can't go by any chart or guide that was made for a different engine type. The only real way to gauge the internal health of the enigne is to perform compression and leakdown tests. As it stands you don't seem to really need to do either.
  6. Ken Madden
    USA
    By the way thank you so much for the response
  7. Ken Madden
    USA
    Well I am getting ready to colortune. We'll see if that makes any difference at all on the manifold vacuum. The bike performs really well lots of spunk. It only has 7,200 miles on it.
