For Sale 1981 xj550 Seca
Discussion in 'For Sale, Trade/Swap, Wanted' started by ctvolkers, Aug 1, 2019.
  1. ctvolkers
    ctvolkers New Member
    Chicago
    No need to sell you guys on the bike---have had it for a few years but with a kid on the way its time to say goodbye. It's been kept in a heated garage the last several winters here in Chicago, can't speak to before then. Since I've had it I've replaced the tires, suspension, redone the carbs, fixed the electrical issue with the kickstand cutoff, replaced the clutch cable, replaced a torn seat (still have the first one if you want to re-upholster), and fixed a leaky petcock. Feel free to follow up with any questions you might have!
      File size:
      284.5 KB
  2. Fuller56
    Fuller56 Well-Known Member
    Pretty little guy. Any ideas of how much you looking to get for it? Good luck with the sale and congrats on the baby!
  3. ctvolkers
    Chicago
    1100—I should clarify—-currently having two problems with it, one easier than the other. First, no speedo cable. Just needs a new one. Second, it starts fine but cuts out when you try to toss it into first. Haven’t had time to dig in and see what’s going on.
  4. Chris Morgan
    Chris Morgan New Member
    Toronto
    I had a similar problem on my XJ. Engine would start fine in neutral but pop it into first and it would die immediately. Just a faulty side stand safety switch for me.
    XJ550H likes this.
  5. garicao
    garicao New Member
    If you're stuck in the middle of nowhere and don't have a replacement side stand switch, i think you can jumper/connect the switch wires to get home. However the wire insulation may be brittle from heat and grungy from location. And, of course, will no longer cut the engine if you try to ride away with the side stand down.
  6. XJ550H
    if it is side stand switch remove sidestand relay under seat this will confirm issue
  7. livedog
    livedog New Member
    maryland
    I'm interested in the torn seat if it is still available.
  8. Joshua Olkowski
    Joshua Olkowski Member
    Los Angeles
    I have the same 4 into 1 kerker. I'm guessing your bike is a little on the loud side?
  9. XJ550H
    so far away
