Battery drained?
Discussion in 'XJ Technical Chat' started by S10gto, Sep 10, 2019.
  1. S10gto
    S10gto Member
    Ma.
    83 Seca 900. Went out this morning to a completely flat battery. She is on the charger now. Curious if any known draws with these bikes. I'm a Auto tech so finding the draw later is no issue just thought maybe a known go to item. Battery looks newish but came with the bike so idk. Have had 0 issues until today.
    Yesterday I installed a new clutch safety switch as the PO removed it but I can't see that being the issue.
  2. k-moe
    You might have turned the key to Park instead of Off when it was last shut down. It's easy to do.
    Rooster53 and S10gto like this.
  3. S10gto
    S10gto Member
    Ma.
    Had the steering in loc but who knows. Charged it up and good now. I grabbed a little jump pack for the trunk just in case. If it does it again I'll get the graphing meter and dig into it.
  4. XJ550H
    only connection to battery with key off is is the clock and red wire to voltage regulator (same wire for both)
    S10gto likes this.
  5. S10gto
    S10gto Member
    Ma.
    Reg was my first suspect but will see. I give her another chance.
  6. k-moe
    The PARK is just a small, barely noticeable, notch past the fork lock position.
    S10gto likes this.
  7. S10gto
    S10gto Member
    Ma.
    I did not know that. Of course my 38+ old switch says nothing these days. Thanks k-moe. That's probably exactly what I did. I'll play around with that when I get home and see if I can duplicate it.
  8. S10gto
    S10gto Member
    Ma.
    You nailed it k-moe! Left the bike on the trickle and what do I see as I walk down the driveway......a Bright Red tail light. Got my key and with a little click back no light.
    Thanks k-moe I owe ya one.
    cgutz and k-moe like this.
  9. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Xj4ever sells replacement stickers to go around the key lock to identify the lock and park...:)
