Why you should replace butterfly (throttle shaft) seals.
Discussion in 'XJ Technical Chat' started by Jetfixer, May 12, 2019.
  1. Jetfixer
    So it is cold and raining off and on so no riding , I finally tore into a spare set of carbs I bought awhile back from Joe Elif . They were pretty gummed up and very dirty inside and out ... I like challenges :D I only wanted these a spare anyway. (Always like spares parts ) so got one carb tore down and soaking , when I pulled butterfly shaft out the seals were toast , I suspect at some point someone tried to soak carbs and this will tear up the seals . There is NO short cut breaking the carbs off the rack is only way ,and one other seals that is super critical is the fuel interconnect rail ....do your carbs right the FIRST time if it leaks fuel onto a hot engine well I dont think I need to explain. Anyway not sure about other carbs, when I rebuilt my carbs(on my seca ) seals did not look real bad but replaced anyway .
    no such thing as spare carbs, just carbs in waiting. now you have to find a bike for them its the right thing to do..
    replacing the seals is needed and you should not have to do it again for several years
    Gonçalo Melo likes this.
  3. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Mine had 18k miles and looked ok but they were not contacting the shafts at all.
  4. k-moe
    Exactly.
    Over time the plasticizers migrate into the atmosphere, causing the seals to shrink and embrittle.
    The process speeds up with exposure to ultraviolet light and/or heat.
    Stickied and edited the title for terminology.
    Jetfixer likes this.
  5. Jetfixer
    So here are some pictures of the carbs before and after one is cleaned . The #4 carb float post was broke at some point , who ever did the repair did a good job drilled hole and put a pin in and JB weld . I have another set of carbs so will probably not use this body , but I might use it as is. 20190514_193254.jpg 20190514_193223.jpg 20190514_193254.jpg 20190514_193223.jpg 20190514_193254.jpg 20190514_193223.jpg
  6. Jetfixer
    So grabbed my other set of carbs , broke down the carb number 4 , got it soaking right now . Looking at this set of carbs there in better shape but were missing the diaphragms. The other set has diaphragms and complete.
  7. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    When I pulled my carbs apart, I found my throttle shaft seals to be petrified. They LOOKED ok, but they were hard as a rock. No chance they were doing the job they were supposed to be doing.
    Beck and Jetfixer like this.
  8. Jetfixer
    I'm hoping this thread will better show why you should take carbs to church . My second set I tore down today seals were soft and pliable look new , but I'm replacing them anyway.
  9. Jetfixer
    Okay finally finished putting carbs back together only took me 3 months ( lol has been to cold to work in garage and was in no hurry either) these carbs were in poor condition , extra soaking on one carb the butterfly seal was totally goo , the butterfly plates were seized and the slides were froze took lots of PB blaster to free them up. The hats were rusted and I'm cheap so cleaned them up ,sprayed with self etching primer and painted with hammer rite silver
  10. Ryengoth
    Wilmington, NC
    If you have the parts and pay attention to the shaft styles and orientation it really is not that bad. Just time consuming when things break during disassembly.
  11. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    I recently tried out the two #11 o rings for throttle shaft seals on my 83 750 midnight so I could get it on the road for cheap. Well, that completely backfired in my face. When I first put them together I had coated the orings in silicone grease and all worked smoothly. A month later and the throttle blades no longer operate properly. They open well enough but take about a minute to return to an almost idle position. My advice, buy the correct seals and do it once. I am so mad I have to pull those flipping carbs again. One because it's a pita, and two because I have it running so awesome.
  12. k-moe
    You do have to work the throttle shafts quite a bit initally when using the o-rings in order for them to work properly.
    Maybe @Polock can chime in about that to clarify. I believe that he's had the same set of o-rings in this machine for several years.
  13. XJ550H
    he has advised me that using 2 #11 x rings works with out working the carbs
    just work them a little more you may not have to redo them
  14. Ryengoth
    Wilmington, NC
    Spray a quick shot of fluid film in the crack of the shaft where it meets the bore. then work them and repeat. the lanolin should last a bit longer until the rubber molds to the shaft.
  15. Polock
    sorry to hear about that. here's the o-rings out of mine after, i don't remember how many years. the slides snap shut like a guillotine.
    the grease should be similar to this stuff, clear and a bit thicker than toothpaste. spray can silicone attacks the rubber.
  16. Jetfixer
    Could be wrong O ring material , Buna or vitron is they type.
  17. Ken Madden
    Ken Madden New Member
    USA
    I'm having difficulty locating accelerator pump seals. I'm getting ready to do an overhaul to replace the shaft seals, Jets, floats, needle and seat, air fuel mixture screws. I have been unable to locate accelerator pump seals. As all have suggested, I would like to replace the rubber on these. Any ideas for a source.
  18. Polock
    what kind of carbs are they? chances are they don't have accelerator pumps
    Beck likes this.
  19. Ryengoth
    Wilmington, NC
    I think you may be thinking the choke piston is a fuel squirter?
    halfbreed likes this.
  20. k-moe
    And the seals on the enrichment plungers (pictured above) are just dust seals.
  21. XJ550H
    xj4ever sells those too
  22. firebane
    firebane Active Member
    Calgary, AB
    So here is the thing... I know that Chacal (xj4ever) is a good source for a lot of this stuff, but unfortunately because of the exchange rate and shipping ordering from him can be QUITE costly for such small objects.
    With that said I see in this post people have talked about using #11 viton orings as throttle shaft seals, but has anyone measured out what a double lip or what size of seal would be necessary to replace the ones that are in there?
    Maybe something with some precise instruments who has their carbs ripped apart could give us depth, width and opening sizes and maybe find something that is easily accessible to all?
  23. Ryengoth
    Wilmington, NC
    I did measure mine with a caliper and mic but I didn't write them down. I ordered square seals that were supposed to fit and went with it. They were a little loose in the bore but squished and fill it when I installed the shaft clips and such. We'll see if they come back to haunt me. I have some 550 carb parts sitting in a tote that I can measure tonight and post dimensions.
  24. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    The cost of the correct seals seems insignificant to me compared to the labour (my time) to go back in there.
    Order new butterfly screws while you're at it.
    Franz likes this.
  25. Jetfixer
    Doubling up the #11 seals works fine ,in my spare set of carbs , my main set has the seals fro XJ4Ever ...I would rather use the seals from Chacal.
  26. Ryengoth
    Wilmington, NC
    11.5mm OD
    8mm ID
    3mm thick
    Alan63 and firebane like this.
  27. SecaMaverick
    SecaMaverick Active Member
    Northeast Ohio
    I agree with the consensus to just replace them with the correct seals, if at all possible. I just rebuilt my carbs for probably the fourth time in 18 years (and this time it's been 10 years). Although I was expecting the throttle shaft seals to be brittle or slightly disintegrated -- I seem to remember using petroleum-based lubricant last time -- I was somewhat disappointed to find them in nearly new condition. But you better believe that while I was in there, I still replaced them and used the correct non-petroleum-based lube.
  28. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    I am thinking about pulling my carbs and rebuilding them very hard to start and takes for ever to warm up. Was looking at the seals cost a lot to have them sent so was thinking about o rings found some online. After it starts have to run on full choke and give throttle slowly or it bogs out bad and have notice cutting out under 2500 rpms and what sounds like a slight ping about half the time. will these work?
    3 mm X 8mm (NBR) Buna-N 70 Duro Metric O-Ring
    3mm Cross Section
  29. XJ550H
    #11 orings is the size and can be combined with #11 x rings 1 of each on each side
  30. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    Keep trying to find #11 O rings when I do a search they do not come up as #11 . trying to find the size for them.
  31. Polock
  32. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    Thank you found them you dont have the # for the x rings do you .I think the reason I couldn't find them I was looking up # 11 o rings and it came up with 3/4 OD or 9/16 OD
    I knew that wasn't right.
  33. Polock
  34. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    Thank you
  35. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    got them in the mail had to buy a 100 of each but only $11.00 for all so very happy.Looking thru post dont guess it makes a big difference what one goes in first.
  36. Polock
  37. Andy Dobkins
    Andy Dobkins Member
    Lonedell Mo
    thanks
  38. Nick S
    Nick S Member
    Washington D.C.
    Planning on doing this job on bike soon. Just to be clear, I should replace the O-rings AND throttle shaft seals? Those are two separate things? I've already ordered the o-rings and I've emailed xj4ever about ordering a set of throttle shaft seals. They're quite expensive but worth it to fix a vacuum leak.
  39. Nick S
    Nick S Member
    Washington D.C.
    Bought the x-profile O-ring that polock suggested. Did you mean to use these in replacament of the actual throttle shaft seals or as the correct o-rings on the fuel line?
  40. k-moe
    The o-rings mentioned in this thread are viable alternatives for the proper throttle shaft seals (which I prefer).
    The o-rings came about at a time when new throttle shaft seals were very difficult to get at a reasonable price.
    The fuel fttings take a somewhat specialized seal, and I recommend against substuting anything else.
    Nick S likes this.
  41. Ryengoth
    Wilmington, NC
    I had no issues fitting viton o-rings in my rebuilds. The V seals are available but they are overpriced and only do a slightly better job at sealing. They do a much better job of splitting than the o-rings do, though.
  42. Jetfixer
    Sometimes it is best to order the best cry once. In other words do the job right the first time , and KMOE is spot on get the CORRECT fuel rail seals , you do not want a leak at these points can lead to a fire.
    Chitwood likes this.
  43. Nick S
    Nick S Member
    Washington D.C.
    @Jetfixer does anyone know the correct size for the fuel rail o-rings?
  44. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    #10 fit the Hitachi's on the XJ700.
  45. Nick S
    Nick S Member
    Washington D.C.
    My fault, should've started with for an '82 xj650 maxim. The carb for that one is a hitachi HSC32
  46. Polock
    WARNING, REDNECK FIX
    i found a o-ring that fit tight in the groove on the fuel pipe but didn't quite go into the carb. then i pushed harder, then really dam hard and it went in, and cut a little sliver of o-ring off as it did
    they haven't leaked in years.
    i don't recommend this, but i can't argue with success.
    your really better off with the real ones
  47. Jetfixer
    Xj4ever has the correct seals , although they look like "O" rings they are flat on the outside and when you put the rail into the body you will feel a slight snap that locks them in place. My local Yamaha dealer actually had them as well. I can't recall price .
  48. ddiggerr
    ddiggerr New Member
    Manitoba
    wow ... I just broke down the carbs and replaced the throttle shaft seals with #11 rings. It worked good for about 10 minutes, then hung up and had to shut it down to get throttle to snap back. I used silicone on rings on reassembly but now I am thinking I will have to break down carbs again to see whats hanging up. I cannot sync carbs in this condition
  49. Polock
    am i the only one who did the o-rings successfully?
  50. k-moe
    Did you work the throttle linkage to "bed" the o-rings in before you installed the carbs?
    I know that others have. I uesd o-rings on my friends Virago without any trouble.
