What yr is this bike?
Discussion in 'XJ Technical Chat' started by xyxj650, Nov 2, 2019.
  1. xyxj650
    xyxj650 Member
    Fergus Falls MN
    Was looking at getting this bike. They have it listed as an 87...? Know that is incorrect. Thought someone here could help me identify what yr. Price is right! Also would this engine fit in an 80 maxim frame? Thanks! Screenshot_2019-11-02-16-03-29.png
    it does look like an 80 650 non yics bike.
    you should check short vin on motor to see if that is different than motor
    http://www.dissingermoto.com
  3. xyxj650
    xyxj650 Member
    Fergus Falls MN
    The motor is what's throwing me off.
  4. dkavanagh
    Rochester, NY
  5. XJ550H
    what about the motor is throwing you off ?
    bike should be 80 xj650 with non yics motor looks correct to me. hatachi carbs.
  6. Timbox
    Timbox Well-Known Member
    If you have access to the bike, take a look at the left side of the triple area under the steering head. It should say the month and yr it was built.
  7. hogfiddles
    It’s an ‘80/‘81 based on the current engine. It is possible to be an ‘82/‘83 with a replacement engine from an earlier bike, though unlikely. Check the head tube. You could also asked them what the title says. They may think the 1 is a 7
  8. xyxj650
    xyxj650 Member
    Fergus Falls MN
    The guy has no idea about it. Has it listed as an 87... Asked him questions and he Cantrell me anything. My prob is the case covers. Look Kinda like newer. Case covers are what makes me wonder. Everything else looks good.
  9. hogfiddles
    Clutch and shifter covers are swap-able, paint-able, engine covers are available as aftermarket parts, etc.....and cover several models and years. If he has no clue, why would he arbitrarily choose 1987?
