Overbore question
Discussion in 'XJ Technical Chat' started by kerriskandiesinc, Nov 3, 2019.
  1. kerriskandiesinc
    NY
    Just curious, on the 750 range, does the maximum overbore allowed, create the '853cc' size of the ( early ) 900....I know the later one was stroked too....anyone any ideas??
    there were kits for this but it requires you to bore out over maxim spec
    kerriskandiesinc likes this.
  3. cds1984
    cds1984 Active Member
    Perth, Western Australia
  4. Timbox
    Timbox Well-Known Member
  5. kerriskandiesinc
    NY
    That isn a bad price at all...especially if you already have a somewhat tired, low compression motor....Wonder how much extra umph you'd likely get though, with 'only' 818cc.....
    Maybe another 4-5Lbs of torque ( always useful) .....maybe 4HP??
  6. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    I would never overbore an airhead due to possible wall warping. That little bit of extra "upmh" could quickly turn into a new upper half. If you have a spare head and piston set go for it and put it on a dyno to record the difference.
  7. XJ550H
    I would think you would have to change the jets some. just think of the different jets between 650 and 750
  8. Timbox
    I love the XJ's but I think if I was was going to go with a big bore kit I would be going with a 1000 or 1100 model that was more designed for it. Love how these bikes work stock, if I wanted more power hp/torque I think I would find another bike.
  9. cds1984
    No change to jets or carbs for 748cc to 818cc with that kit.
    Might help something, but the low end power was what I was after.
    Worked a charm.
