Anyone here ever tried this...Colortune alternative?
Discussion in 'XJ Technical Chat' started by RJ C, Sep 20, 2019.
  1. RJ C
    RJ C Member
    MN
    yes. it is a bitch to remove the ceramic from the plug. when the epoxy gets hot it will soften . you want to use slow cure not 5 min epoxy(brittle)
    just remember it will become a flying projectile if it fails
    I made one for an 8mm plug for a single cylinder bike.
    wear face shield when using
  3. XJ550H
    i also have a real color tune
  4. RJ C
    RJ C Member
    MN
    That’s what I figured could happen, but wanted a professional opinion.:eek:
  5. RJ C
    RJ C Member
    MN
    You bragging, selling or giving it away? ;)
    Do they work like they say?
  6. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Yes, the color tune plug definitely work. Great for getting initial pilot screw setting.
    RJ C likes this.
  7. RJ C
    RJ C Member
    MN
    Thanks.
  8. XJ550H
    yes and no. I went with safety of a proven product. some things just shouldn't be hacked/Mac Gyvered
    no
    if you can pry it from my cold dead hands:(
    yes quite well
    RJ C likes this.
  9. RJ C
    RJ C Member
    MN
    Perfect response! :D
  10. RJ C
    RJ C Member
    MN
  11. Jetfixer
    Just buy the real colortune plug ...worth every penny.
  12. RJ C
    RJ C Member
    MN
    Probably will, but I had the parts to make it, so I did.
