Dead Cylinder but has compression spark and fuel?????
Discussion in 'XJ Technical Chat' started by SM85, Nov 4, 2019.
  1. SM85
    SM85 Member
    Canada
    Guys,
    I am stumped on this one, if you become to know me I only ask for help when I am completely jammed up.
    I have a 1983 XJ650k Maxim. Cylinder #3 is not running (Cold), it has 150psi compression, spark (verified spark with a Spark Length Tester at 6mm), and new spark plug that is gapped correctly. The spark plug has fuel on it when I remove it from the cylinder.
    If you cover the #3 Carburetor air collection port, above the intake side of the carburetor, engine RPM will increase. Seems #3 header will pickup some temperature, cylinder seems to be running when covering the #3 carburetor air collection port with finger. I thought I had put the main air jets in backwards, but I checked anyways and I did not. On number 3, I screwed the pilot needle further out to check if increase in fuel would help.
    Thinks I have tried...
    Thought of a lean condition.
    The air boots appear okay, i put an inspection light in the boots and cannot see any light.
    I also ran a rubber hose on the tip of my propane torch, and no rpm increase in that area.
    I have fully disassembled and done the carburetors, carbs were hot tank dipped for cleaning and blew all passages out with brake cleaner and air (paying attention to the 32mm hitachi carb diagrams). Polished slides and verify diaphragm operation. Polished all needles and float seats and unplugged the emulsion tubes. I set the float levels to precisely 3mm for each carburetor and set the Pilot Fuel Screws 3 turns out.
    This is starting to get frustrating. I am obviously missing some small thing.
    Any advise is greatly appreciated.
  2. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Sounds like it's getting quenched (too rich) and the sync is off between 3 and 4. Did you sync the carbs? Do that first if not or you will be chasing your tail on EGT and mix tuning.
  3. SM85
    SM85 Member
    Canada
    Thanks for reply! , does it matter that the cylinder isn't running for vacuum sync? I have a vacuum gauge all ready to go.
  4. Timbox
    Timbox Well-Known Member
    Sounds like you are almost there, did you happen to read this https://www.xjbikes.com/forums/threads/in-the-church-of-clean.14692/ That is the correct way to clean the carbs. As far as trying to do a sync without all the carbs and cylinders firing, well just don't. It would be a waist of time.
    I don't know how many CV style carbs you have cleaned, but they are hard to do correctly the first time. It can be done, but most take a few times to get them correct. I have had to pull carbs many times to get them correct before I took the time to do them by way of the "church".
    Get that dead cylinder running before you go any farther. If you have not checked the valve specs that could be causing some issues too. Did you do a bench sync when you had the carbs off? You can get them very close just with that.
    Is your battery new or in really good condition. Lost of us have issues with low or bad batteries that make the bike start hard or lack of good spark.
    Keep at it, if you get that frustrated, just take a brake from the project until you feel you can work on it with a clear mind. Best of luck.
    Franz likes this.
  5. Polock
    no, not at first
    swap the plug with one from a hot cylinder
    3 turns out is about the limit, try going in
  6. SM85
    SM85 Member
    Canada
    I have jumped the battery with a new excellent commerical HD battery and no difference, then I did the full spark test.
    I have swapped hot plugs in, and I have tried screwing in the pilot fuel inwards as well.
    I followed that Church of Clean writeup and did much other research before starting. But I did not bench sync, would this cause a cylinder not even to idle?
    I am running the engine with #3 vacuum line (The one that runs to the spigot plugged off), and the spigot in prime mode for a gravity feed to fill the bowls. I also am not running the air box yet, would either of these cause an issue?
  7. XJ550H
    motor should run fine with out air box for testing purposes
    how did you plug off the nipple on 3? test it for a vacuum leak
    also if you have not installed the airbox boots bench sync the carbs
    can you see the slide move up on 3 when opening the throttle?
    have you checked the diaphragm for holes?
  8. Timbox
    If you can reach them, test the diaphragms by pushing them up and keeping your finger over the oval opening. If it stays up of slowly comes down the diaphragm is working. If it slams down, it has issues. A hole, rear or just not seated when the top went back on.
    I would take some compressed air and blow out that #3 cylinder to make sure it is good and dry. If you have spark on #3 and you said the plug gets wet from fuel, it could just have too much fuel in there to fire???
    Did you do a wet set of the carbs?
  9. Ryengoth
    Wilmington, NC
    No, the piston is tied to the crankshaft so it will be creating vaccum if the engine is turning at all. You can even do it with the starter and the plug wires pulled, just to get the initial shaft alignment in the ballpark. You will need to re-tweak at revs based on the book with the engine running.
  10. Ryengoth
    Wilmington, NC
    Bench sync is a much better alternative than the starter-crank method since you can see where the butterfly is in relation to the fuel orifices. That's what I used and it worked well for the no-filter initial tune.
    Turn the mix screws in all the way and then out 2.5 turns to start with on all 4. If you have more than 3 full turns you are flooding the cylinder on stock jets.
  11. XJ550H
    air collection port? thr kidney bean shaped hole?
    can you confirm slide is lifting on carb 3?
    have you tried swapping the 2 and 3 spark plug wires, to see if the problem follows the wire? you can also swap caps to see if it is the cap as a second step.
    also swap spark plug 4 with 3 to ensure known good plug, even if it is new.
    then trim back wire 3 to remove any corrosion at the end of the wire.
    is the mixture screw the same as the others course threads vs ultra fine? could be a carb from an older rack was swapped in.
    washer under main jet was it flat or cupped could be letting in extra fuel.
    main fuel and pilot fuel jets reversed? Been there done that.
    plug is wet is it black sooty too?
    have you ohmed out the ignition system
    XJ650 models:
    Pick-up coils:
    1982-84 XJ650 Maxim: 650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
  12. Jetfixer
    How I do a bench synch , I use 2 business cards cut in two ( IE you have 4 pieces) put one under each butterfly plate ...turn the idle screw in until it contacts the stop , adjust number one synch screw till you get a slight drag on the card leave it in place, move to number 2 do the same , move on to number 4 ..now turn idle screw in slightly ...now you should have a slight drag on all 4 pieces of card it the all feel the same your there. Remove the cards hold carbs up to strong light you should see a slight bit of light at bottom of butterfly plate. This should get you in the ball park. One thing I recommend I'm running 82 Honda CB750 coils , these can be bought new still and have replaceable plug wires. Cycle Recycle part 2 has the coils and wires and caps , the coils are around 40$ each these mount in stock location . One thing i also would recommend swap the plug cap from the hot cylinder to the cold cylinder...the cap maybe bad see if this follows problem. Cheers
  13. kerriskandiesinc
    NY
    84-91? 900R Kawasaki coils have replaceable wires too...I've run these successfully on some of my XJ's....
    Do NOT use silicone HT leads......I didn't like the way they performed, looked or...went together
  14. Polock
    what's wrong with them? they come in colors, what more could a man ask for
  15. kerriskandiesinc
    NY
    Yes, the green matched my (re painted) green,black and gold Kawasaki perfectly...they seemed flimsy, didn't fit the plug cap screw very well....and looked like they were 'falling apart', internally.....maybe they've gotten better, since the 90's...?
  16. Timbox
  17. SM85
    SM85 Member
    Canada
    Hello everyone! Before I post this, I want to thank everyone with all their advice so far. I have taken the last few days to recheck everything mentioned here.
    I have dismantled #3 carburetor again, Fuel and Air jets are in correct position. All passages are still clear and clean. The vacuum slides open on all carburetors when cranking the throttle. Performed the bench sync. I even hooked up the vacuum line to the fuel tank again, checked it for damage and used hoseclamps to make sure a tight seal.
    The #3 cylinder still only runs when covering the air collection (Oval) port at top of intake mouth. So Strange.
  18. Ryengoth
    Wilmington, NC
    Is there a secondary fuel tube in the bowl that could be clogged?
  19. XJ550H
    covering that hole would cut off air to main and pilot jet. that would mean you are sucking more fuel into the cylinder
  20. sybe
    sybe Active Member
    NYC - Brooklyn
    you might want to check the jet sizes and spray starter fluid on #3 carb boot / engine manifold. if the engine surges then you have an air leak at the boot. if it still does the same then start spraying parts of the carb to make sure you arent leaking any air. The carbs are more finicky than an upset wife.
  21. XJ550H
    the only thing he has not confirmed that he tried was swapping the plug wires for 2 and 3. it could be the plug wire connection at the coil has failed
  22. Timbox
    If you put your hand over the back of the #3 carb it will start to run. What that does is force the pressure change in the carb, leaning up the air and making the fuel mix going into the #3 cylinder richer. #3 will not run on idle but will it will it run on 1/2 throttle or full throttle? If if you have IR temp gauge you can check the exhaust header while you are testing and not burn your hand.
    I know us coming back to fuel issues is driving you nuts, but if you have compression, you have spark, the only think it can be is the fuel. I would mention valve spec but you said the compression test is good. I wish you luck on finding this problem.
  23. Ryengoth
    Wilmington, NC
    I had a similar issue with the 550 and it was the secondary fuel supply tube from the bowl. Clogged solid from debris after a full rebuild and an initial run period. Does the 650 have that as well?
  24. XJ550H
    the brass rod for the enrichment circuit yes hatachi and mikuni have then and the wells in the carb bowl. at some point the cylinder should run as pilot jet would work once bike was warmed up
  25. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I had a similar problem and it turned out that about 1/2 of the intake gasket was missing, causing a big air leak. Replaced the gasket and that solved the problem.
    Jetfixer and XJ550H like this.
  26. Ryengoth
    Wilmington, NC
    Was the plug wet or dry?
  27. tabaka45
    Brunswick, Georgia
    Dry. Too much air.
  28. Ryengoth
    Wilmington, NC
    In this case the plug comes out wet so either the float is not shutting off the bowl, the idle circuit is partially clogged or it's a spark strength issue.
  29. Jetfixer
    Just a thought ,pull carbs swap the emulation tube with another from the carb that is "hot", swap the needle and seat and float and same with jets ...put carbs back together and reinstall and see if this "fixed" cold cylinder and problem went to the other cylinder. ...one other item open fuel bowl drain screw , measure how many cc's of fuel is in each bowl if one is low compared to the other float level could be off.
  30. XJ550H
    maybe he should just swap sparkplug wire on 2 and 3 and see if the issue moves before ripping out a non removable part from the carbs
  31. tabaka45
    Brunswick, Georgia
    What is he talking about when he says "the #3 Carburetor "air collection port,"" ?
  32. XJ550H
    the kidney shaped port at the top of throat airbox side of the carb that feeds the air jets. if covering this hole makes bike run better he probally has a vacuum leak
  33. tabaka45
    Brunswick, Georgia
    Thanks. Didn’t know what he was referring to. Strange that his plug is wet but enriching it makes it run.
    Timbox and Ryengoth like this.
