New tach wiring
Discussion in 'XJ Technical Chat' started by skurtaan, Nov 24, 2019.
  1. skurtaan
    skurtaan New Member
    Norway
    Hi guys!
    So I have just removed my Atari, and is connecting up a new tachometer.
    Before I removed the atari and connected the new tacho, the RPM was working correctly. Now with my new tacho, it stays at 0. The backlight is the only thing working, hehe.
    Grey is the Engine signal, right? As shown in picture below, these are the wires I need to connect up my new tach with, am I right?
    Cheers!
  2. k-moe
    raskal likes this.
  3. skurtaan
    skurtaan New Member
    Norway
    I have done the wiring changes "how to remove the rectangular instruments". Both backlight and frontlight are connected, and working.
  4. XJ550H
    gray wire is signal wire from coil and tci
    what brand tach did you buy ?
    not all of them work like a yamaha tach
    skurtaan likes this.
  5. skurtaan
    skurtaan New Member
    Norway
    That’s what I thought, thanks.
    I bought a cheap one of ebay, universal fit(picture below). Can I use a multimeter on the signal wire to see if the tach gets signal?
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    Hard to say what tach you bought exactly from a pic, I think it's the one in the following link. All the ones I looked at indicate the yellow or yellow/black wire is the signal wire but there are no specifics that indicate what that signal should be (i.e. switch ground from coils, wrapped around a spark plug lead). Some of these gauges have a long black wire as ground and a short black wire as switched positive. Yikes. Can you share more about the specific model and exactly how you have ALL the wires hooked up?
    https://www.ebay.com/itm/13000-RMP-...a=0&pg=2047675&_trksid=p2047675.c100005.m1851
  7. skurtaan
    skurtaan New Member
    Norway
    Yes, that's the tach.
    So I got the Long black and short green connected to my bike's black.
    The Short Yellow/Black to my bike's grey cable.
    and the Long red, and short black to my bike's brown cable.
    Wire Connection:
    Long red- positive, Long Black- Negative
    Short Green- Ground,Short Yellow/Black-Engine Signal
    Short Black- power/ignition lock positive
  8. skurtaan
    skurtaan New Member
    Norway
    Wire Connection:
  9. XJ550H
    you may have to wrap signal wire to spark plug wire to get a signal.
    problem is the tach adjustable for 1,2 4 cylinder motorcycles?
    Yamahas have a wasted spark ignition. That means that both cylinder pairs off of the ignition coils fire EVERY time piston come to top dead center, intake and exhaust.
    jayrodoh likes this.
  10. skurtaan
    skurtaan New Member
    Norway
    I actually don't know if it's adjustable. It just says universal.
    So by wrap the signal cable, you mean the signal cable from tach goes into the spark plug wire? And where on the spark plug cable should I connect the signal cable? Im kinda green to connecting a wire onto a spark plug wire.
  11. XJ550H
    if that is how it works you would wrap the wire around the sparkplug wire. you could use a second wire to do this with and use a connector for the connection.
