Front form rises a lot under hard acceleration
Discussion in 'XJ Technical Chat' started by xj750y, Nov 30, 2019.
  1. xj750y
    xj750y Member
    Nl
    Hi,
    Xj750 41y 1984
    My front fork is working fine under braking however under hard acceleration it rises a lot (max way out) this is not comfortabele (the bike goes up and down a lot). I have never had this on other bikes.
    The rear shocks are new and are not part of the problem.
    I reinstalled the shocks with new oil seals and new oil but no improvement.
    Thanks for help.
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    Hmm, Maybe new springs needed? Progressives will also lessen that effect I think.
  3. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    You can also just make preload spacers out of pvc pipe but @a100man recommendation is best
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    X3. My guess is your springs are worn out. You can measure them once you pull them out but when they are worn it will sit lower at rest and will move around a lot more under acceleration and braking.
  5. XJ550H
    when you take out the springs to check you may as well replace seals
  6. xj750y
    xj750y Member
    Nl
    Fixed. There was not enough oil in the forks.
    Jetfixer likes this.
  7. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    I use Race Tech for all my suspension needs, Race Tech Emulators will do wonders for any of the old Damper Rod type forks, well worth the money.
    Cheers, 50gary
    Edit, I just saw your last comment, Race Tech will tell you the proper level of oil to have in your forks. It's best measured with springs out forks vertical, and compressed. Then you fill each fork to a prescribed line, example: 4" from top of fork tube to oil surface, it's also important to get the level exactly the same in each side. I would start with 15wt. oil.
