finished my xj 550 seca
Discussion in 'Hangout Lounge' started by andy willi, Jul 26, 2016.
  1. andy willi
    andy willi Member
    doncaster UK
    well after 5 years i have finally got my xj 550 up and running passed its English MOT test first time , the bike is an american import , it has covered 22000 miles and is now as near as original as i can get but having problems getting the original silver and black decals ( the bike is in red ) will post some pictures when i can get them off my other pc .
    if anyone has the decals for this bike please contact me as it is all i nead to finish it
    andy
  2. k-moe
    Start a conversation with Chacal.
  3. andy willi
    andy willi Member
    doncaster UK
  4. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Very nice. Glad you kept the stock look.
    smeagol21b likes this.
  5. andy willi
    andy willi Member
    doncaster UK
    well it has been two and a half years from me finishing the bike to get to ride it i have now finished it completely has had another paint job and decals fitted , the decals were the problem i could not get them , i did not use the bike last summer but i will this summer as i can now show it off , i think this has turned out well and it is possibly the only red xj 550 in the uk .
    andy
    Plug, Joris, chacal and 5 others like this.
  6. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Nice looking machine
  7. XJOE550
    XJOE550 Active Member
    Inverness, FL
    Very nice work! Beautiful outcome! I have the same bike, but nowhere near being finished. Although I ride mine every other week, it has an issue having to do with a stretched primary chain. Only noticeable at idle. I also need to remove a couple of dents removed and repaint. Looking at your beautiful bike is good motivation. Thanks for sharing and enjoy riding her this summer.
  8. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Nice work!
  9. k-moe
    What's the idle set at?
    The 500 has a hydraulic primary chain adjuster, and is known to be a tad slack at idle. Bump the idle speed up and the tapping should diminish.
    It's unlikely that the chain has worn enough for it to be the issue.
  10. XJ550H
    ^^+1 set your idle to 1200 rpm and the sound goes away
  11. andy willi
    andy willi Member
    doncaster UK
    hi thanks for the comment i had a rattle on mine it was the small dowel pin on the rear of the clutch housing got a local machine shop to replace it no rattal now ,
    andy
  12. XJ550H
    Nice Its a North American Seca wheels are a giveaway .if you look around you may be able to locate the dual disc setup used in Europe on the 550
  13. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Absolutely stunning, arrest-me-red!
  14. andy willi
    andy willi Member
    doncaster UK
    hi have the twin discs but not going to fit fit them yet as i don't ride it fast will see how it goes .
    andy
  15. andy willi
    andy willi Member
    doncaster UK
    quick up date now fitted 4 into 1 motad exhaust so i can send the original pipes of for rechroming not as loud is i expected and the sound is good will se how i get on with it ,
  16. dkavanagh
    Rochester, NY
    Nice! I was looking for the Motad setup, but I decided to buy one too long after they shut down!
  17. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Make sure that the clutch cable clears the header pipe and not melt to it. Nice looking exhaust and better looking bike.
  18. andy willi
    andy willi Member
    doncaster UK
    many thanks for your comments have ordered some heat shield wrap for the clutch cable .
    i wont be keeping the exhaust on as i want the standard two pipe system back on when it is re chromed, so in the spring i will be putting it back to standard and selling the motad exhaust as i wont be needing it any more .
    andy
  19. lostboy
    I zip tied the clutch cable to the down tube of the frame to keep it away from the headers.
  20. andy willi
    andy willi Member
    doncaster UK
    had first ride out with the motad fitted and ran well but have now got starting problems , think it is down to running to rich and over fueling .wont start when hot embaracing outside the bigist bike shop in doncaster but the backfire woke them all up . it was a cold day
    andy
