will xs100 speedo and tach work on a xj750
Discussion in 'XJ Modifications' started by XJ550H, Nov 13, 2017.
  1. XJ550H
  2. mlew
    The speedo should but I cant say for sure. I think all the Yamahas use the same ratio speedometer . That one i know will work on any XS or XJ1100.
    Please buy them for me, I need them for my XS11.
  3. Jetfixer
    If it is an electrical tach it will work ...the speedo as well
  4. k-moe
    Yes, and yes, but only if you do the necessary wiring modifications to the bike (unless you're making a housing for the systems monitor, and keeping it hooked up).
  5. JetmechMarty
    JetmechMarty Active Member
    Coldwater, Mississippi
    I concur, the tach is not cable driven.
  6. Bix
    Bix Member
    Victoria BC
    i know this is an old thread, but did you ever find a way to get the tach accurate enough?
  7. XJ550H
    I ended up getting cluster and sending it to someone who needed it for an 1100
