1988 XT350 cam won’t spin
Discussion in 'XJ Technical Chat' started by BigVic65, Jan 1, 2020.
  1. BigVic65
    BigVic65 New Member
    Wheeling, Illinois
    I need you’re big brains. I’m rebuilding a 1988 XT350. New valves, springs, guides, valve job, etc. Using Plasiguage I checked the clearance between the cams and cam caps and it was within specs. When I torque the caps to 7.2 ft/pounds the cams won’t spin. They did before I disassembled it. Any thoughts? Thank you in advance.
    original cam and caps?
    are caps on correctly and in correct spot?
    did you use assembly lube?
    replasti guage them
  3. Hillsy
    Hillsy Member
    Did you remove the plasti-gauge before you torqued the caps? Sounds like something is still in there?
  4. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    How are you trying to turn the cam?
