Tubeless 550 (seca)
Discussion in 'XJ Technical Chat' started by a100man, Feb 5, 2020.
  1. a100man
    a100man Well-Known Member
    Bedford, UK
    Hi All
    Apologies if this has been done to death - quick search did not reveal.. Just received a new Maxxis ProMaxx 100/90/19 for the front of my 550 and it is tubeless tire/tyre. Doubtless I could refit it with a tube but do I have to? Will the rim I have be OK to run tubeless (its the 'italic' Euro style)? Actually same goes for the rear which is also a Maxxis - I have to swap rims due to an out of round drum.
    ta!
  2. Toomanybikes
    Tsawwassen bc
    Rim should be marked for tubeless application. And rim will have a small lip inside that a tubeless wheel may not have.
  3. a100man
    Bedford, UK
    I'm guessing you mean the tubeless rim has the lip - yes?
  4. Toomanybikes
    Tsawwassen bc
    Yes, got it backwards
