I'll paypal $10 to anyone who can make a drawing of the valve bucket retaining tool. XJ650.
Discussion in 'XJ Technical Chat' started by pillowmaster50, Mar 28, 2020.
  1. pillowmaster50
    pillowmaster50 Member
    You gotta use calipers.
    Thanks!
  2. hogfiddles
    Jetfixer, k-moe and Timbox like this.
  3. pillowmaster50
    I'm asking so I don't have to do it that way again haha.
  4. raskal
    raskal Active Member
    Abbotsford B.C. Canada
  5. pillowmaster50
    because I'm isolating and I want one now
  6. XJ550H
    will photos with dimensions work for you?
    Mesurements in MM or inch?
    my Caliper seems to be hanging out with my 10 mm sockets so Im out at this time.
  7. hogfiddles
    I’d rather use the ziptie method, cuz:
    1. You can rotate the bucket to get the notch. With the “tool” you have to make sure the bucket is indexed just right so when it rotates, the notch stops where you need it. One the ‘tool’ holds the bucket down, you’re not going to be able to spin the bucket.
    2. some extra zip ties, and you can do two valves at once.
    k-moe, XJ550H and Nuch like this.
  8. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    I found this point to be very important. Being able to spin the bucket is really, really helpful.
  9. XJ550H
    I have tried the tool and now just leave it in the box did not like it. very time consuming
    k-moe and hogfiddles like this.
  10. Timbox
    I agree, using the zip tie or wire method is the way to go. Faster IMHO and I think if you can keep metal on metal contact out of the picture is a good thing.
  11. Franz
    Franz Well-Known Member
    Scotland UK.
    Tool can crack the head if the cam is rotated the wrong way which is another good reason to use the zip tie or wire method.
    Jetfixer, k-moe and hogfiddles like this.
  12. hogfiddles
    I have two of them, and they just sit in the shim box. I haven’t used either of them in probably 10 yrs
    Jetfixer likes this.
  13. pillowmaster50
    Offer still valid
  14. Polock
  15. hogfiddles
    That’s cheating, too
    raskal likes this.
  16. Polock
    what do you expect for $10
  17. hogfiddles
    Lol... that’s why I use zip ties
