XJ650 CDI wires - wich one go where
Discussion in 'XJ Technical Chat' started by Full Tilt, Mar 29, 2020.
  1. Full Tilt
    Full Tilt New Member
    Nova Scotia
    I got the wires mixed up that plug into the CDI on my xj650 1981.
    Can anyone point me in the right direction to figure where to plug each color in or where to find a picture with harness plugged in?
    thank you
  3. Full Tilt
    Nova Scotia
    thank you , that CDI seems a little different - mine has TD14-02 on the side.
  4. XJ550H
    the TCi wiring is same for 550 650 and 750.
    1100 and 650 turbo have a different set up
  5. Full Tilt
    Nova Scotia
    thank you for your help - I got it figured out now. didn't help that I had a connectivity issue with the red wire. soldered it back together and that got it started.
    cheers
