carb rebuild!! For 81’ XJ550 maxim!! Need threads
Discussion in 'XJ Technical Chat' started by Roman daley, Apr 16, 2020.
Tags:
  1. Roman daley
    Roman daley New Member
    New york
    Any advice or threads/links/videos to help start this rebuild!
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
  3. Roman daley
    New york
    Thanks man it’s funny I was just starting to read through the information overload you had!much respect!i will start reviewing and researching before I even start ripping anything apart.
  4. Jonathon Kent
    Jonathon Kent Member
    Rochester NY
    That’s a very smart thing to do; as I am sure that you will soon become aware, a great many posts on this technical chat are of running issues; and majority of running problems stem from the carburetors. I was one of those people who had to re build my carb rack 3 times and “clean” 5 times before I finally got my bike to start and even run on its own without my fiddling with it a bunch. It pays to do the homework first before the tinkering with these carburetors.
  5. Roman daley
    New york
    My pops always told me to do the job properly the 1st time through so I appreciated those links and what they were saying. I just bought this xj and it’s been sitting in a garage for 20plus years. I bought it from a mechanic and he had it running. But I’ve been having idle problems and I did an oil change. Found gas in the oil while I drained it. So I’m guessing it’s carbs. 0054DEB1-2794-4D89-B1B0-C3B8E8481FA0.jpeg
  6. Jonathon Kent
    Rochester NY
    It’s funny you say that about your pops. My pops also told me something when I was much younger; “ if something is worth doing, then it is worth doing right. If your going to do it right then that means you do it the right way the first time” I thought back to that after my last rebuild of my entire carb rack and that’s when I fully believe that I got every single port cleaned and when I re installed the carbs the bike fired up right away and ran like a champ all on its own.
  7. a100man
    a100man Well-Known Member
    Bedford, UK
    My father was a farmer, he never had enough money to do anything properly and bodged his way through life - taught me everything I know.
    jayrodoh and Simmy like this.
  8. XJ550H
    this is for the X but still mikuni carbs
    Cleaning your Mikuni carbs
    from the suziki mikuni carb rebuilding tutorial refered to in info overload I downloaded the manual before it was no longer available
  9. hogfiddles
    And, unless your petcock was left on PRI, you have an issue there, too
