Does anybody ever vent valve covers????
Discussion in 'XJ Modifications' started by craniumcrunch69, Jan 14, 2008.
  1. craniumcrunch69
    craniumcrunch69 New Member
    pittsburgh,pa USA
    was wondering if anybody vented their valve covers. something like this except picture it on a seca.
    sorry the only think i could find to illustrate my ?
  2. Alive
    Alive Active Member
    Queensland, Australia
    Hmm interesting.
    Can't say I've heard of anyone doing it on a bike.
    What benefit would one get from such a modification?
  3. MiCarl
    You're not venting valve covers. You're venting the engine.
    The check valve in that vent line is called a PCV valve for Positive Crankcase Ventilation.
    Instead of being vented at the valve covers our XJs are vented from the top of the transmission, on the left, just ahead of the air box. The stock set up has a hose going from the vent up to the front of the air box.
  4. Gamuru
    Gamuru Guest
    Granite Falls, WA
    :lol:
  5. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Yeah.... what they said.
  6. Hired_Goon
    Hired_Goon Member
    Oz
    Is that venting or a dry sump engine????
    Not sure why you would on a piddly four but anythings possible.
  7. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
    That piddly four probably puts out more horses then any piddly stock eight... I used to be in the tuner crowd. We may have only had 4 cylinders but we still got down the track in 12 seconds. :twisted: Most of the guy s you see with riced out Hondas are not even close to having a really fast car. Just a really loud one.
  8. Deathmetaldan
    Deathmetaldan Member
    Sunbury PA 17801
    k20 crx's do it better :)
  9. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
    Word! I love CRX's
  10. craniumcrunch69
    pittsburgh,pa USA
    back on track here. usually people vent valve covers to help keep oil from blowing past the valves, especially on a boosted engine. i was just wondering because of the age of most of our bikes (and hopefully there are some turbos on this forum), if anybody ever tried this....guess not. also another question: what size (I.D.) is the stock fuel line on a 550 seca. all my lines need replaced and i was gonna go braided stainless (maybe somebody can give me an AN line size) thanks
    P.s. I LUV turbo hondas muhahahahah
  11. Polock
    younz should try a search at kzrider.com, i saw a thread about that once, had something to do with helping the rings seat
    it's a 'burg thing
  12. RickCoMatic
    Venting the Cam Cover would be difficult. There's a lot of oil being slung around in that top cover.
    Venting the Can Cover would likely mean Oil would be escaping through the topside vent.
    There's a sizable baffle in the side cover to deal with any possible sucking -out of oil at the lower end.
    Nice looking engine you have there.
    I'll bet the Go-Kart can really haul butt!
    I'm a 60-Degree V6 Man, myself.
    3400 in a 04 Monte Carlo.
    It's a heavy Coupe ... but, it goes good!
  13. chacal
    6mm ID, or about 1/4"
