My XJ 600 S diversion '95 (problems tachometer)
Discussion in 'XJ Technical Chat' started by RobinAL85, Apr 24, 2020.
  1. RobinAL85
    RobinAL85 New Member
    The Netherlands
    Hello im Robin from the Netherlands and im new here.
    I did a conversion of my diversion into a naked, everything is running smoothly just waiting for a few items and then the project is finished, only one thing I tried to find it here in the forum but I can't find the solution.
    also the speedometer isn't working fine but I think that's because its cheap shit that's why I ordered normal gauges now and hope that one is working better.
    I can't get my aftermarket tachometer working, ive got the universal cheap ones with the following cable colors:
    RED-backlight
    BLACK-backlight
    (this I got working)
    Green- Negative ground
    black-positive
    black/yellow- engine signal(high voltage)
    I tried almost everything with the black/yellow cable, on the ignition coils(orange and if I remember correctly the grey one, on the original cable(grey), on the sparkplug, on the sparkplug cable. but I didn't get my tach working.
    I was hoping I would find my solution here.
    Thnx for reading.
    (also uploaded the bikepic)
    Cheers
  2. SQLGuy
    SQLGuy Well-Known Member
    I think you need to post some pictures of the tach.
  3. RobinAL85
    The Netherlands
    here the pictures, also the speedometer doesn't start at 0, but minus 20, so a new set is on the way, but also ordered a different set, but I think it's not important which tachometer it is, but how to connect the wires, because they are all universal products
  4. SQLGuy
    I'm not sure why they're saying (high voltage). High voltage for the ignition system would be several thousand volts.
    Looks the same as this one: https://www.ebay.com/itm/Motorcycle...757085?hash=item4b7011b9dd:g:FFYAAOSwp2Vd6J1s
    Which the seller says is not compatible with any Yamaha except Virago models. However, my XV750 uses TCI, too... so it really should work with an XJ if it works with an XV.
    Yes, from your and his information: short black to switched 12V. Short green to chassis. And short yellow/black should be able to go to either grey or orange in the harness.
  5. RobinAL85
    The Netherlands
    thnx for the reply, I will try it again with the new one maybe the other one was broken.
  6. RobinAL85
    The Netherlands
    I tried again and still not working properly, I did the positive and negative with the new one, and the signal wire I connected to the sparkplugcable( 1o times wiring around the cable), this gave a little life in the tach but not enoug, does anyone has any ideas for me how to fix this, im 2 weeks working on this problem and still not working! already tried to connect the yellow black wire in the harness--> also not working. should it be connected to the cdi or something? also tried to connect to red/white wire from the coils-->no success, also tried the grey and orange wire in de harness-->no success...
    so what can I try more (the backlights I got working and the speedometer now is on "zero" instead of minus 20.
    thnx for reading
  7. SQLGuy
    Normally electronic tachs get their signal from the coil drive, not from induction from the high tension wire.
    Have you tried wiring it that way - with the signal wire connected to the orange or grey wire that drives one of the coils?
  8. RobinAL85
    The Netherlands
    I think I do, i connected the wire to the metal off the coil(orange and the grey) or should i connect the wire to the wire itself?
    thnx
  9. SQLGuy
    To the wire itself. Either the orange or the grey.
  10. RobinAL85
    The Netherlands
    Alleight I will try that today, thnx for the response
  11. RobinAL85
    The Netherlands
    Connected it directlt to the orange wire... no response too bad
  12. RobinAL85
    The Netherlands
    Ok i opended the fairing to expose my ignitor unit, i connect twhe wire to the grey one, no succes, then the orange—> no succes , now i tried the red white one from the ignitor unit but it gave 4 times the value on the tach..?? Dont understand it
  13. RobinAL85
    The Netherlands
    Ok succes! I tried the white green cable from my pick up coil to the ignitor unit and now its working?!!
  14. Marchy
    Marchy Member
    Canada
    Great looking bike btw Robin nice work!!
    having same issue so to confirm everything is still working.......cuz I’m going to use your leg work to get mine going lol
  15. Marchy
    Marchy Member
    Canada
    Lol I don’t have a white/green back to drawing board
  16. Shaban Mustafov
    Shaban Mustafov New Member
    Bulgaria
    hello robin i have the same problem as yours would you tell me where is this white green cable or pics. i will be grateful
  17. Rooster53
    North, FL
    Do you have the same bike - 1995 XJ600 Diversion?
    If so, XJRider has a nice schematic and you can see the White / Green wire attached to the pick-up and to the Igniter Unit - I don't know the bike all that well but I would suspect if you wanted to tap into that wire with an aftermarket tachometer you would do it at the TCI.
    The Ignitor Unit also appears to have a dedicated wire for the tachometer that appears to be a Yellow / Black wire. I would try that wire first as it is already routed to the instrument cluster.
    https://www.xjrider.com/gallery/albums/userpics/10002/1992_xj600_wiring_diagram.jpg
    And, we don't know which tach you are trying to install, some are designed to monitor the input for a zero crossing signal (Pickup) and some are designed to detect a differential input change of polarity (coil primary).
