Gear shifter lever problem..
Discussion in 'XJ Technical Chat' started by Rodney Brown, Apr 30, 2020.
  1. Rodney Brown
    Rodney Brown Member
    Bronx, n.y.
    Hey guyz!! Heres the deal.
    All of a sudden , nn w/o prewarning( That I could detect) my gear lever just just became " loosened" ( forgive my absence of the technical term).
    My 81',xj750 seca, currently shifts from 1st to second gears, but that's it!! The shifter literally goes all the way up to the top before it clicks into 2nd gear!
    Nothing but " slake" in between.
    Clutch seems to operate the same. I didn't strip any gears that I could tell. Again, she was shifting great , let's say, 15 mins from on stop to the next.
    What happen guys?? Thx in advance. Screenshot_20200429-111646_Adobe Acrobat.jpg
  2. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    as simple as the gear linkage has come loose?
  3. Rodney Brown
    Rodney Brown Member
    Bronx, n.y.
    Is it external?
  4. raskal
    Yes. From the foot lever, follow back to where it enters the transmission case
  5. Rodney Brown
    Rodney Brown Member
    Bronx, n.y.
    Okay. I'm familiar with the part. Looked the same to me. Ima take a pic of it 2morrow. Hitchu then Raskal.
  6. raskal
    I couldn't find the right picture, but they are all kinda similar
    Make sure the bolt labeled 13 in this pic is there and tight
  7. Rodney Brown
    Rodney Brown Member
    Bronx, n.y.
  8. Rodney Brown
    Rodney Brown Member
    Bronx, n.y.
    Hay raskal!! I cant seem 2 post a video of the gear..I checked the screw. Everything in tact there. The ENTIRE lever moves up and down, from top to bottom, w/o the clutch deployed. Has to be something internal.
