Orange thing around piston
Discussion in 'XJ Technical Chat' started by eigenseca, May 13, 2020.
  1. eigenseca
    eigenseca Member
    Arkansas
    82 Maxim 750. What is this orange thing around this piston? I can see it on some of the other pistons but not as much of it. Also that spot on the left is a piece of gasket material that fell down in there.
  2. Franz
    Franz Well-Known Member
    Scotland UK.
    The orange thing is an O ring which is an oil seal. You only need to replace them if you have stripped the cylinder head and juggs off the engine.
  3. eigenseca
    eigenseca Member
    Arkansas
    Why can I see it on this piston but not others?
  4. Franz
    Scotland UK.
    You should be able to see them unless they are covered in oil. They must be there otherwise you will have oil leaking between the juggs and the crankcase when you get the engine running. What do you see?
  5. Franz
    Scotland UK.
    Orange O Rings 900 f
  6. eigenseca
    eigenseca Member
    Arkansas
    Oh I see them now. The piston in the picture is just the cleanest one. The rest of them I can see a hint of orange around them. Thanks!
    Franz likes this.
