1986 Fazer FZX700 project
Discussion in 'Other Motorcycles' started by Avi, Apr 5, 2020.
  1. Avi
    Avi Member
    Brooklyn NY
    Good afternoon all,
    I am working on the fuel tank and I found out that it's kind of a strainer basket with too many to count pinholes spread all over the tank.
    My question is does anyone have a recommendation for a tank sealer or maybe another method to treat the tank for these leaks?
    I might look for a replacement tank out there but for now I would like to treat this tank and use it.
    Thank you, be safe and stay healthy!
  2. xHondaHack
    Orange CT
  3. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    if its on the bottom I would try a 2 ply repair with fiberglass.
  4. Avi
    Avi Member
    Brooklyn NY
    Thank you @xHondaHack and @Simmy
    I looked at the Por-15 fuel tank sealer but since the Caswell is 3 x the $$$ I would like to believe it's also a superior product.
    I looked also at soldering the holes but there are too many and I am afraid that it will be a never ending story with new holes popping up so sealing is a better solution.
    Thanks again, be safe and stay healthy!
  5. Fuller56
    Fuller56 Well-Known Member
    I have used both the Caswell and POR-15 kits and found the key to either is meticulous prep of the tank. Years ago I used the Caswell with not so good prep. It lasted for a long time but eventually pealed off the interior of the tank in small sheets. Better prep then and applied the POR-15 with excellent results. The tank did not have any holes or leaks, this was just preventative as I had had a tank on another bike fail due to rust through. 10 plus years later all is well. I have nothing bad to say about the Caswell, the failure of it is all on me.
    John
  6. Avi
    Avi Member
    Brooklyn NY
    Thank you for the info @Fuller56
    I do see that there are many options out there for fuel tank coating/sealing and I guess you can never know which one is the best or will work the best on ones tank.
    I just saw another one called Red-Kote and it has some good reviews as well.
    I will try to read some more and try to pick one for my tank.
    Decisions decisions...
  7. Fuller56
    You are very welcome. I used Red Kote 1 time and it did not seal the rust holes. I had a different tank cleaned at a radiator shop and they applied Red Kote and soldered a hole and it was fine. I prefer POR-15.
    John
  8. Avi
    Avi Member
    Brooklyn NY
    @Fuller56 Thanks for the replies and the info.
    I am debating now between the Por-15 kit and the Caswell
  9. Andrew Nichols
    Andrew Nichols Active Member
    Minneapolis, MN
  10. Andrew Nichols
    Minneapolis, MN
  11. Timbox
    Timbox Well-Known Member
    I keep looking for them within a two or three hr drive. Never seem to be lucky enough to get my hands on one. Nice looking bike.
  12. Andrew Nichols
    Minneapolis, MN
    Tomah isn't far from Minneapolis, MN and I'm looking to sell it now that I've got it running and polished. It's a little on the small side for me but it is fun! I have a new (used) starter on order as this one makes some noise. IMG_20200827_131100276.jpg IMG_20200827_131028132.jpg IMG_20200827_131042730.jpg
  13. Timbox
    I saw a black one in your area for $1800.00 for sale, could not find your add. Good luck on the sale. She will sell, the sport version of the XJ700X imho.
  14. Andrew Nichols
    Minneapolis, MN
    I haven't posted it on Facebook Marketplace or Craigslist yet, waiting to get the title back from the state first (and hoping to get the starter noise fixed first as well).
  15. Timbox
    I see, I am sure you didn't like the $164 for a title now days in WI. I guess they have to pay for the E pubs web site for all the WI DMV needs. I should not jab them too bad, they are fast with the epubs and they get titles out quick. imho
  16. Andrew Nichols
    Minneapolis, MN
    MN has you fill out a form online now and then a rep will follow up with an email requesting more info, then he doesn't get back to you for awhile and that's where I'm at right now. I currently have an in-person appointment in mid-October just in case.
  17. Timbox
    Wow, well misery loves company sorry to say. I hope it goes well for you and that you get the paperwork to make her your baby.
