Xj900s diversion swingarm dimensions needed
Discussion in 'XJ Technical Chat' started by skylrk62, Jun 9, 2015.
  1. skylrk62
    skylrk62 Active Member
    Illinois
    Does anyone know the dimensions of a XJ900s Diversion swingarm. I need the width at the pivot. The length from pivot to axle. Also does this swingarm share the same pivot bearing as other XJ's? Has anyone ever tried swapping this on their XJ650,700,750, 900(old) bike? I have a good setup right now, but I'm looking into a longer wheelbase and it seems this might be the longest? I'm not sure if the older XJ900 shares the same dimensions?
    edit: I'm thinking it will need to be cut and shortened and have the bearing housing rewelded on the width of the pivot to fit a j650-750 frame.
  2. k-moe
    My recollection is that the Diversion 900 was a clean slate as far as the frame and swingarm are concerned. That is not to say the divvy swingarm won't fit though.
  3. skylrk62
    Illinois
    Cool, thanks. Maybe some of our UK & Euro members can shed some light on this? Any of you guys have a Xj900S?
  4. skylrk62
    Illinois
    I guess I might have to be the one who figures it out? It would be nice to know if the xj900-xj900f swingarms are the same length as the diversion? I would save $$$ not having to import a divvy swingarm to The USA.
  5. skylrk62
    Illinois
    Looks like I found a guy overseas that fit a divvy swingarm to a XS1100. Now the question is the Xs1100 frame wider at the pivot than the XJ650-900 frames?
  6. skylrk62
    Illinois
    I ended up buying a Divvy swingarm and shaft. I'll let you guys know how it turns up. It's being ship from overseas, so a couple of weeks.
  7. Stephen Downey
    Stephen Downey Member
    Ohio
    how'd your swing arm turn out?
  8. XJ550H
  9. XJ550H
    Stephen Downey likes this.
  10. Stephen Downey
    Ohio
    Wow that's super impressive. I'm blown i really like that bike!
