Different wheels?
Discussion in 'XJ Modifications' started by Ken w, Jul 18, 2020.
  1. Ken w
    Ken w New Member
    New York
    Curious if anyone has did any homework on what different rims will swap onto a xj750, is there a way to go a little wider in the back?
  2. PavelK313
    PavelK313 Active Member
    Fairfield CA
    Bike is limited on rear tire width by shaft tube.
  3. Ken w
    Ken w New Member
    New York
    Yeah I was looking closer and see there really isn’t any wiggle room,I’m more interested in finding a nice set of spoked rims didn’t know if there was anything I could put right on
  4. XJ550H
    some virago spoke rims fit rare as hens teeth
    wider tire some have hammered in the shaft tube to give clearance, does not seem wort it to me.
    there is a few old threads about it.
  5. XJ550H
  6. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    A 140/70/17 width tire will fit in the rear. I only mention that just to give an idea of how much tire will fit in the swingarm of the XJ750.
    Your next question will be "what wheel did you use". My answer will be "I built a custom wheel two tonnes of work." I'm not saying forget about it.
    But...I view people with OCD as relaxed and well adjusted folks.
    Cheers, 50gary
    Kickaha and Rusty81 like this.
  7. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Xj 900 diversion.....
  8. Ken w
    Ken w New Member
    New York
    Like this rim? I like the style
  9. sybe
    sybe Active Member
    NYC - Brooklyn
    Wish i known, i just threw that rim out after removing the rear clutch hub. I would have given it to you for free. Those rims are getting harder to come by.
    Make sure when you buy it that it has the rear clutch hub. They tend to separate the two on ebay.
  10. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    That is not a 900 Diversion rim.
    Appears to be a 900 Seca and if memory serves it is only slightly wider 2.15 to 2.50. Same tire 120/90-18
  11. Franz
    Franz Well-Known Member
    Scotland UK.
    Yes is is the same as mine 900 Seca.
  12. Yammaat
    Yammaat Active Member
    Netherlands
    140/70/18 fits the stockrim too. I rode it for 2 years with innertube. No problem.
  13. Franz
    Scotland UK.
    Did that tyre fit the 900f. Did you use a wider tyre on the front wheel?
  14. Yammaat
    Netherlands
    It did fit the 750 Secarat rearrim. Pain in the ..s to get it on the rim but functioned just fine and had a good look.
  15. Franz
    Scotland UK.
    I think the swingarms are the same thanks.
  16. Yammaat
    Netherlands
    I was experimenting with the height of the front-rear end. A couple of mm's can make quite a difference when galloping through the mountainranges with speed and luggage..lol
    Height of the tires and frontfork through the clamps made mine almost perfekt now in handling, to my preferences that is.
  17. Franz
    Scotland UK.
    I might get one of those tyres for my 900. As long as your bike is handling well that's great.
  18. Yammaat
    Netherlands
    Watch the height of your fronttire if you don't want to change the rake of your frontend. It's minor but noticable.
    Franz likes this.
  19. Franz
    Scotland UK.
    I will experiment a bit with it to get the handling right.
  20. Minimutly
    West Wales, uk
    The 900 swingarm is longer, also the shock bolt is in a different position on the pumpkin or whatever you call it - thread on here somewhere recently....
    Franz likes this.
