Vacuum hose connection?
Discussion in 'XJ Technical Chat' started by Mark1971, Jul 21, 2020.
  1. Mark1971
    Mark1971 New Member
    Clay Center, Nebraska
    '81 XJ650 Maxim
    Bike is new to me. When looking at the parts diagrams, it shows "Plugs, Blind" on the Carb->Manifold boots of Cyl 1, 2, and 4 but not 3. My cyl 3 had just a bare brass connector that looks like it should have a plug on it. Putting my finger over it improved idle, so I got another cap and capped it.
    Now I read on another thread, that there is supposed to be a vacuum hose connected to this that helps shut the fuel off? When I changed the oil, it did smell pretty "gassy" like there was fuel in it. Thinking I had a float valve issue I pulled the carbs off to clean them. Since I have this thing apart I want to fix it right. Is there supposed to be a hose here? Where does it connect to at the other end?
  3. Mark1971
    Mark1971 New Member
    I do have an original petcock and the hose is in fact missing. I will replace it. One mystery solved thank you.
  4. XJ550H
    4mm id vacuum hose
