Where do I start?
Discussion in 'XJ Technical Chat' started by Josephclinton, Jul 25, 2020.
  1. Josephclinton
    Josephclinton New Member
    St. Paul, MN
    I've got this neighbor who moving out of our little ghetto into the woods a few hours north of the twin cities. I was helping him and noticed a motorcycle in his garage, dusty and forlorn. I asked about it, as I never heard him on a bike. Well, he used to ride quite a bit until end of 2017 when he got hurt at work and couldn't ride any more. The bike has sat in his garage since then. Along the way, some hoodlum broke in and tried to chisel the ignition cylinder off to hot wire it. I knew he didnt want it, and asked a price.
    Hundred bucks, I'll even help you roll it to your garage.
    Now, I havent been on a bike in 20 years and that was just f***ing around on dirtbikes as a kid. I'm reasonably mechanical, but sadly my dad hated cars and my subburban school district got rid of autoshop the year before I got there. I do basic work at home, and have probably f***ed up as much as I've succeeded.
    I've gotten as far as reading about the VIN numbers and identifying the bike, its a 1982 Yahama XJ650 Maxim made in November of '81. I know the battery is trash, as are the tires. Ignition cylinder shouldn't be too hard.
    So, I guess, where do I start? Its my first bike, it needs some love, where would you start with such an endeavor? I'm aware its a project and wont be free, but it should be fun.
  2. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    What you have is a low mileage, original, nice bike. What you DON'T want to do is start taking things apart. You just may have a good running bike that needs a few parts. If it ran in 2017 it will run in 2020 or 2021 with little work. I had a XJ650J sit in my garage for 7 years and all I had to do is flush the tank and drain the carbs, put in new fuel with "seafoam" and I'm still riding this bike. To be fair the bike was stored with a full tank of gas so there was no rust in the tank and it had a heavy "seafoam" treatment prior to storage.
    You will need to make sure the engine is not seized. If it is not your in good shape. Get a new ignition switch and put it in.
  3. XJ4Keeps
    XJ4Keeps Member
    North Shore, MA
    Start by deciding what you want from the bike and how much time and money you're willing to spend. Understand that it will probably take more of both than you think. If you're on a limited budget, think safety and function first, cosmetics last. You said the tires were shot, so that's first on the list. A thorough brake inspection should be next (rear brake shoes should definitely be replaced immediately). Wheel bearings should also be checked before you go anywhere, as should your throttle and clutch cables. Carbs will probably need attention if the bike hasn't been ridden for three years, but there's a slight chance you might get lucky there, depending on how and where it was stored. Same with the fuel tank and petcock. If you're not used to working on bikes, probably the best initial investment you can make is to take it to a reputable shop in your area and have a talk with a pro. Once you get started, you'll find plenty of good advice (and probably every part you'll need) right here on this site. Good luck, and enjoy the journey.
  4. XJ4Keeps
    XJ4Keeps Member
    North Shore, MA
    Good advice from StahlMaster. Since your battery and ignition switch are lunched, the very first thing you should do is turn the crank by hand to make sure the engine isn't seized.
  5. Josephclinton
    St. Paul, MN
    How would I do that?
  6. XJ4Keeps
    XJ4Keeps Member
    North Shore, MA
    The easiest way is to pull the spark plugs, spray some Mystery Oil or similar lubricant in the plug holes and let it sit for a few minutes, raise the rear wheel off the ground, put the bike in gear and bump the rear wheel forward. If it turns relatively easily, you're in business.
    Josephclinton likes this.
  7. XJ4Keeps
    XJ4Keeps Member
    North Shore, MA
    If it doesn't turn at all, you've got issues.
  8. Josephclinton
    St. Paul, MN
    Easy enough. Thanks!
  9. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    I would NOT take it to a pro bike shop - they will likely rubbish it, put you off and try to sell you a new "learner" bike - unless you know of an old time enthusiast run outfit?
    Engine first - check it turns over (oil down the bores, let it sit overnight at least), new or jumped battery from car battery to crank it over after you've done the turning it over by hand thing.
    Get a manual and learn how to follow the wiring diagram.
    Get or make a fuel bottle - you'll need one later anyway to set the carbs.
    I would take the carbs off to clean the bowls out and the richener oriffices at least, idle jet if it looks gummed, also main jet.
    If it has oil in it and the "rebuilt" carbs don't leak fuel start it!
    By this point you will hopefully have learnt enough to take it further - you have really only scratched the surface - tyres, bearings, brakes, cables, tank, proper carb rebuild, paint? It will take you months to do it all right, but will be well worth it.
    cgutz likes this.
  10. XJ550H
    once you confirm motor turns (which is no big deal if it doesnot turn) start with the basic maintance list listed in the factory service manual or aHaynes manual.
    clean electrical connections.
    my first 2 items because the do not cost anything to do.
    Clean and lube the ignition switch
    Your Gas Cap and You
    motor turns then
    Bigfitz's AIRHEAD VALVE ADJUSTMENT with Pics - parts I & II.
    when you have the gas cap off.
    look at inside of fuel tank for rust. siphon out the fuel get it all out
    clean tank if needed, replace fuel
    read this it has links and info on everything you need to do
    The Information Overload Hour
    this link lists specs for ignition system and charging system, ohm them both out to see if they are in spec
    your bike is a collection of systems that work together, go through each system.
    you have started to do this with the cleaning of the fuel cap and ignition system. minimum work on fuel cap would be cleaning it and replacing o rings.
    glass fuses? consider replacing with a new fues box blade style or inling blade fuse holders. both will cost the same to do.
    your goal should be to get bike running before doing any of the secondary repairs.
    then you can spend money on brake system rebuild front and rear checking wheel bearings.
  11. Minimutly
    West Wales, uk
    Turning? Cranking? Running? These are important terms.
    I would say turning is mechanically turning, by removing the plugs, selecting 4th and pushing it - or putting a spanner on the crank.
    Cranking is using the battery, solenoid and pushing the button. This is a brit thing - in the States what would you call it?
    Running is simply firing the fuel, noise and smoke coming out - degrees of this vary obviously.
    So, turn it over,
    Get it cranking,
    Get it running
    All before doing any work on clutch, brakes, lights, shocks etc. Just don't be tempted to go joyriding.
  12. XJ550H
    same on this side of the pond
    turn by hand methods
    crank by starter
    running any motor turning and burning fuel and can roll along under its own power.
    though I still dont know what a tyre is;)
  13. Minimutly
    West Wales, uk
    Don't let it get to you - the English language is a mess - it mostly sounds Ok, easy to use and understand, but when you look at different sounds of letters, words etc, it shows it's roots. My first language is Welsh, nice and easy phonetic language, yes has maybe a lot of harsh sound ing "ll"s, ch"s and so on, but that's not unique. No guessing anyway.
  14. Franz
    Franz Well-Known Member
    Scotland UK.
    Sook, squeeze, bang, blaw, induction, compression, power, exhaust the four stroke cycle. That's an old one.
  15. kosel
    MInneapolis, MN
    Second Monday of every month at Diamond's Coffee Shop in NE Minneapolis is the Antique Japanese Motorcycle Club. Great group of people with tons of experience. I'm usually there on my 650 Seca.
    Josephclinton and Franz like this.
  16. Minimutly
    West Wales, uk
    IMG_1254.JPG Very nice looking seca there in your avatar Kosel, I have one myself, bought as a frame with an engine and seat. Similar in many ways to the op of this thread, si I did the "oil down the bores, turn it over, strip the carbs, crank it start it" thing. You should have seen the amount of dead wildlife that came out of the vance &hines exhaust!
    Now it has a front wheel, tank, most controls, ignition switch. The smoke that it came with has gone, it runs as sweet as, but Still loads of work to do before I ride it. It will get done, but these things can't be rushed.
    kosel and Franz like this.
  17. Josephclinton
    St. Paul, MN
    Awesome. Thats the joint right by Tattersall, right?
    I'm a brewer at Fair State and would happily trade beer for technical help as I get digging into this thing.
  18. kosel
    MInneapolis, MN
    Yes, same building. You'll see the bikes out front, weather permitting. If you're brave enough, it's also the starting point of the Icycle Derby, held every January 1st.
  19. Josephclinton
    St. Paul, MN
    Very cool. Heres hoping I have it up and running by January
  20. Josephclinton
    St. Paul, MN
    Well here we go!
    I installed a new ignition cylinder, starter button, battery, and fuse panel. Got it all wired up, put a little oil in each cylinder, turned it over, drained the gas tank into a clean white bucket(two little specs of rust, otherwise clean but skanky smelling gas) and got it to fire off a little ether down the bore. Brakes work and feel smooth. Four cans of degreaser and it almost looks clean enough to take in public, preferably someplace with poor lighting.
    She's ready to have the gas tank reattached and filled up to see if it starts on its own.
    The negative-
    All the bowl drain screws are stripped out. I pulled one bowl off while the carb was still mounted and it was actually clean as a whistle, albeit not "church of clean" clean. Some of the wiring is real crusty. The left side exhaust fell off right at the foot pedal, it had been bird-shit welded together and was being held together with a few hose clamps. The boots between the carbs and cylinders are pretty crusty, starting to get some dryrot cracking.
    Who knows, maybe by summer I'll have to buy a helmet because its running!
  21. Timbox
    Joseph,
    Sounds like you are starting to see some positive improvements and signs of life with the bike, that is great. As far as those brakes feeling good, clean them out. Take that top off the Master Cylinder and look to see if that fluid is nasty brown. Brakes are a big safety issues and really need to be verified. With out weather cooling down so quick this yr, you might have a long winter to work on her.
  22. Josephclinton
    St. Paul, MN
    Will do. Ill flush an replace the fluid.
  23. Minimutly
    West Wales, uk
    Haven't you got it making noises yet?
  24. Josephclinton
    St. Paul, MN
    Today in fact.
    It ran. Hot damn boys, she ran.
    I left the petcock on prime accidentally, so that may be part of the issue, but gas started pooling under it, leaking out of #1 carb I think. Once it warmed up a little it would just rev up and up, until I shut it off.
    but she ran.
    hogfiddles likes this.
  25. cgutz
    cgutz Well-Known Member
    SE South Dakota
    It's ALIVE!!!!
    Check the oil for gas, since a leaky petcock/float valve can leak gas into the crankcase. If you haven't changed the oil, now is a good time anyway.
  26. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Next step, find any vacuum leaks that cause the revving.
  27. k-moe
    Check the date codes on the brake lines. More than 6 years old and rubber, replace them.
    Why You NEED TO REPLACE Original brake lines w/pics
    Assume that the master cylinder hasn't been rebuilt either, or the brake calipers.
    ALL of those rubber parts are service items and NEED to be replaced somewhat regularly.
    If you can't stop, you won't go very far.
    As for the fuel problem: You have a carb (or more) that's in need of attention. Even on prime the fuel should never overflow out of them.
    Carbs have rubber parts in them too, and they are at least as old as the brake lines.
