Valve cover gasket RTV
Discussion in 'XJ Technical Chat' started by vashtsdaytona, Jul 25, 2020.
  1. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    Are you guys doing RTV on your valve cover gasket? I think by convention a little would go in the corners of the half moon.
    Are you guys doing that? More? None?
  2. JCH
    JCH Active Member
    seattle wash
    I put a little bit around the half moon rubber seals and lightly grease the gasket with some silicone grease.
  3. Franz
    Franz Well-Known Member
    Scotland UK.
    Yes round the semicircle.
  4. XJ550H
  5. vashtsdaytona
    Fargo
    Follow up. This new gasket from Yamaha. These gaps supposed to be here? I don't have old gasket anymore to compare. Not pinched or rolled. Just no rubber there. This gap exists on both sides
  6. vashtsdaytona
    Fargo
  7. AG650
    AG650 New Member
    K1K1R3
    I just received a new rubber valve cover gasket from Len at XJ4Ever (great service, by the way) and installed it earlier today. Just used the tacky spray to hold it in place on my 1982 XJ650 RJC Seca. Will let you know how things hold together once I put engine back in frame and fire it up. See attached pic of reassembled engine.
    Regards,
    Andrew
    Bikes:
    1982 XJ650RJC SECA
    1982 Honda CB900C (Custom)
  8. vashtsdaytona
    Fargo
    How about the gap I pictured?
  9. vashtsdaytona
    Fargo
    After looking at more reference photos I think gap is normal and that must be blind hole under there
  10. Mezzmo
    Mezzmo Active Member
    That gap is normal, its a blind hole on the outside and the gasket seals on the inside edge. Nothing to worry about....
  11. XJ550H
    cam covers should be checked for warpage when replacing gasket
