Oil filter direction
Discussion in 'XJ Technical Chat' started by Suvoth, Sep 4, 2020.
  1. Suvoth
    Suvoth Member
    Moncton, NB
    Ok. One side says front and one side doesn't. Does front mean facing me or facing the front of the bike?
  2. JCH
    JCH Active Member
    seattle wash
    I recommendation that you purchase a factory service manual online in PDF form for under 10 bucks .
    Large Bolt with o-ring.
    Cover,notch on cover go's up into recess on block.
    Spring first into cover
    Washer rest on spring
    Concaved section of filter rest on washer towards exhaust headers not engine block.
    Large o-ring on cover.
    Notch on cover straight up
    Not too tight,grease the end of the threads of the large bolt with anti seize to ease install on to block.
    I use silicone grease on the o-rings and reuse the o-rings several times before replacing without any issues.
    Andrew Nichols and Franz like this.
  3. bigfitz52
    "Not too tight" = 11 ft/lb (132 in/lb) "too tight" being open to wide interpretation...
  4. Suvoth
    Suvoth Member
    Moncton, NB
    So you are saying front facing front front of bike.
  5. XJ550H
    order of things
    notice the angled side towards spring
    Suvoth likes this.
  6. Suvoth
    Suvoth Member
    Moncton, NB
    I reinstalled it, front facing my front tire/front of bike lol
  7. bigfitz52
    Yes, "FRONT" marked on any part generally indicates "front of bike" not you holding it in your hand.
    If you look at the 'stack' carefully, you'll see that the slightly concave side of the filter provides clearance for the spring; the spring presses the flat side of the filter against the motor; and the thin washer protects the rubber seal on the filter from the spring. If you analyze what's intended here, you don't need the book, it makes perfect sense. One more tidbit: right on the filter housing above the bolt "1.5 kg-m" is cast into the housing. That is the torque spec in kilograms per meter, an oddball connotation since the world seems to have settled on newton-meters (or foot p0unds) for that. (It directly converts to 10.849520776814849 ft/lb, so 11.)
    Suvoth and JCH like this.
  8. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I have had my bike since new, and even after 30+ years of oil changes, I have to look at this picture almost every time I change the filter LOL.
    kosel, k-moe and Suvoth like this.
  9. JCH
    JCH Active Member
    seattle wash
    Me too... but it doe's make sense the way it is installed if you stop and think about it for a bit.
