Unidentifiable ports in float bowl Hitachi HSC32
Discussion in 'XJ Technical Chat' started by Robert W Blair, Nov 18, 2020.
  1. Robert W Blair
    Robert W Blair New Member
    Canada
    Hello
    There is a small port from the top of the bowl shell to the bottom of the inside of the bowl.
    It seems to have a fitting inside it.
    It does not permit fluid flow.
    Does anyone have a reference for it, what it should do normally?
  2. mlew
    Its the inlet jet for the enrichment(choke) circuit. It needs to be cleaned to allow fuel to flow. the orifice is small, a single strand from a wire brush will usually clean it out
  3. Robert W Blair
    Canada
    Thank You very much.
    Once clean will fluid visibly flow, such as carb cleaner?
  4. k-moe
  5. k-moe
    Also please keep all questions about your machine in a single thread. The history of what has been done makes it much easier to be able to help you as you refurbish her.
  6. XJ550H
    #80 drill bit glued into a q tip shaft use only if you have problems clearing the hole.
    yes there is a brass insert down that tube
  7. Robert W Blair
    Canada
  8. hogfiddles
    That is the enrichment well, and there is a very tiny non-removable jet down there. You MUST get it unclogged.
    Franz likes this.
  9. Robert W Blair
    Canada
    Got it, thanks
