Looking for jets #195 81 Seca 750
Discussion in 'XJ Technical Chat' started by Robert W Blair, Nov 18, 2020.
  1. Robert W Blair
    Robert W Blair New Member
    Canada
    Hello
    Does anyone have a source where i can buy jets for the Hitachi carbs in 1981 Yamaha Seca 750.
    My bike runs very well, i’m cleaning the carbs and want to replace the jets. I have all the new parts except the following;
    I have pulled #195 jets from the carbs.
    I have not found a supplier who has this size.
    Thank you
  2. mlew
    Did you click on the link at the top right corner of the page and send Len a parts request?
  3. Robert W Blair
    Canada
    Thanks, i will do so
  4. Toomanybikes
    Tsawwassen bc
    Are you talking about air jets in the top of the carb? And did you replace the throttle shaft seals?
  5. Robert W Blair
    Canada
    Hello
    Actually, these jets were from the bottom side.
    No have not replaced the seals
  6. Polock
    how did it run with those jets in it?
    should have a 120 and a 40 in it so maybe something isn't marked right or not how we're used to seeing it
  7. Robert W Blair
    Canada
    Hm, I do not hsve that option, do uyou have an email address for Len?
  8. Robert W Blair
    Canada
    It ran very well, at all levels, start, low speed, accel and high speed.
    I removed 43/120 [bottom] and 80/195 [top] all clearly marked
  9. Robert W Blair
    Canada
    In the Church of clean says
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca Canadian models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Main FUEL Jet Size: #120
    Pilot FUEL Jet Size: #43
    Main AIR Jet Size: #80
    Pilot AIR Jet Size: #195
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-14
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    Idle RPM's: 1,050 rpms
  10. Polock
  11. Toomanybikes
    Tsawwassen bc
    I don’t that they ever made a 195 main jet for hitachi carbs.
    Where in Canada are you Rob ?
    I have all those main and pilot jets on hand if you need them. And throttle shaft seals as well.
  12. Robert W Blair
    Canada
  13. Robert W Blair
    Canada
    Good news.
    I am in BC
    I have received some ‘o’-rings in the kit i purchased; could those be throttle shaft seals?
    ps - i ordered the #195’s from Len
  14. Toomanybikes
    Tsawwassen bc
    Those 2 orings that come in those kits no one know what they fit. And those 195 air jets where missing or damaged?
    And where in BC ? I’m in Tsawwassen.
  15. Robert W Blair
    Canada
    Terrific
    Pleased to meet you.
    I live by Fort Langley and work by Tsawwassen!
    The kit contained jet sizes 122, 120, 112, 80, 43, & 40.
    They were unaware of the spec for 195.
  16. Robert W Blair
    Canada
    I have another post anout my bike
    “Unidentifiable ports in float bowl Hitachi HSC32.”
    i’ve poked well into both ports on 4 bowls using carb cleaner.
    I can feel and enter the jet passage.
    Only one bowl permits fluid flow through this port.
    I had ultrasonic’d the bowls.
    I am seeking more knowledge about this port and the brass tube that extends into it from the carb body.
    I expect that they need to be cleaned out and ready to pass liquids.
    I’m trying to rig-up some tiny nozzles to force liquid and air through these. I’d like to remove them to understand the whole circuit.
    Any experience is appreciated.
  17. Robert W Blair
    Canada
    ‘Mlew’ had replied
    “Its the inlet jet for the enrichment(choke) circuit. It needs to be cleaned to allow fuel to flow. the orifice is small, a single strand from a wire brush will usually clean it out”
  18. Toomanybikes
    Tsawwassen bc
    I have heated the bowl with carb cleaner until it boils the clog. If all else fails I have lots of extra carb bowls.
  19. Toomanybikes
    Tsawwassen bc
    Nobody sells kits with air jets, and unless you lose one I never replace them.
  20. Robert W Blair
    Canada
    Thanks for your reply.
    How much are you charging for 4 carb bowls?
    What do you know about the tube that enters that passage in the bowl?
  21. k-moe
    The 2 "extra" o-rings are for the float bowl drain screws on the Virago carbs IIRC.
    Robert W Blair likes this.
  22. Robert W Blair
    Canada
    Hi, what are 4 carb bowls worth?
  23. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    It's probably worth your time to actually get the jets clean so that carb cleaner will shoot through. Costs less than replacement bowls. I know it's a pain but it can be done.
  24. Lwmcd1
    Lwmcd1 New Member
    2184 cr 426 lake panasoffkee Florida 33538
    I went there because I lost a jet.
    I didn't see a link to order one.
  25. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    A badly clogged enrichment circuit jet in the bowl is difficult to clean by poking at it. Using a tiny drill bit to ream it out works well. Len at XJ4EVER also sells these in the correct size. Caution, they are very delicate and you wouldn't want to snap one off. I used a small 22 ga syringe from the local farm store as a drill bit holder. Cut the sharp tip off, insert the bit and crimp with pliers. Rotate by hand. Go slow!!
    There are no links to order. Just send an email, describe what you need, he'll send you back lots of info.
  26. Lwmcd1
    Lwmcd1 New Member
    Yes sir the circuit jet in the bowls were clogged big time.
    I cleaned them so that carb cleaner would passing through.
